Wipers turn on out of know where so I pulled the fuse and now my dome light won't turn off dose anyone have a clue what it could be???
Any DIC Codes?
If you have DIC codes, try looking them up and if not serious, try resetting the codes and see if your issues go away. If the codes cannot be cleared, then you either have sensor issues, grounding problems or some other type of electrical problem.
Just a note. Corvette Grounding strap issues are common. Could be a corroded, loose, or broken ground. Search this forum for grounding locations and you should see a link to a diagram.
