Fuel pump swap
Old Nov 11, 2012 | 05:24 PM
ttz's Avatar
ttz
Default Fuel pump swap
Will a standard in-tank walbro 255 fit to replace the stock pump in an 01, or is the racetronix one needed? Also, anyone know how low the gas needs to be in order to pull the pump from an 01?
Old Nov 12, 2012 | 04:48 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
suscribing. Any Fuel Pump DIYs?
Old Nov 13, 2012 | 01:12 AM
dreww's Avatar
dreww
Unless its a late model c5, the fuel pump is a cake job.
Get driver rear tire off ground, then remove it. There is a circle panel on the fuel tank to pull the pump out.
drop in replacement is easier, but more expensive. I did the racetronix hotwire kit and walbro 255 pump
Old Nov 13, 2012 | 01:44 AM
bumble-z's Avatar
bumble-z
Drop the level to One eighth of a tank of gas.
Old Nov 13, 2012 | 09:36 AM
Eifdawg's Avatar
Eifdawg
Cruising
Default Fuel pump replacement
I replaced mine last year on a 2001 Z with a Lingeneflter Walbaro. It wasn't hard, but all the fuel in that tank is coming out one way or another. It's a pain getting everything back in just right, but doable for average joe. Be careful torqueing your bolts back on, I snapped one very easily.
Old Nov 13, 2012 | 12:35 PM
ttz's Avatar
ttz
Thanks for answering my question.
Would a regular in-tank walbro 255 swap in fine or is the racetronix one needed? It seems the racetronix one comes with a bucket. Not sure if that bucket is needed to replace pumps.
Old Nov 13, 2012 | 02:17 PM
Eifdawg's Avatar
Eifdawg
Cruising
Default 255?
Not sure what you mean by Racetronics bucket. I just looked at Lingenfelter's website and that Walbaro pump is the exact setup I stuffed in my fuel tank. I also bought the tank seal at the bottom of the page. Been good to me so far. As the site states, it will not work for 2003 1/2 model years and higher, they went top mount after that.
Old Nov 16, 2012 | 09:40 PM
ttz's Avatar
ttz
By bucket, I mean the white part the pump sits in.
To Fuel pump swap
