[Z06] Best Cold Air Intake kit?
Old Nov 11, 2012 | 11:48 PM
dtpugh's Avatar
dtpugh
Default Best Cold Air Intake kit?
I'm new to the Corvette group, I have a 2001 Z06, it has the stock intake on it, but the air box was taken off and had a BlackWing filter put on, it needs to be cleaned/replaced, but I'd rater just buy a new CAI kit, so what is the BEST intake on the market for the price, preferably cheaper than $500. any help is appreciated! Thanks in advance!
Old Nov 12, 2012 | 02:00 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
http://www.halltechsystems.com/product-p/kbls6conv.htm
THIS COMPARISON DYNO WAS JUST INSTALLING THE HALLTECH C5 KILLER BEE II CONVERSION, RETUNING, VS THE BLACKWING.
MODS:
LS3 416ci
Trickflow 235cc Heads
Halltech Killer Bee II Conversion Pak Installation of the Halltech Killer Bee II Conversion Package replacing only the Blackwing netted +24RWHP/+25lbs-ft
Kooks 1 3/4" Longtube Headers
Kooks Catted X-Pipe
24x/25x 0.63x"/0.63x" Camshaft
Nick Williams 102 mm Throttlebody
FAST LSXr 102 mm Intake Manifold
Reckart Performance Custom Dyno Tune
584.78 RWHP/547.7 LBs-FT
The Halltech Killer Bee II Conversion Pak gets rid of the old Delphi MAF sensor and replaces it with the probe style LS7 MAF. Comes with the Pigtail wire conversion harness. We have been selling this conversion package to many dealers that are modding the C5s with bigger LS motors and huge cam and head packages. This intake is way too much for the stock LS1 or LS6. The Halltech Venom II handles that.
http://www.halltechsystems.com/product-p/v2024.htm
Old Nov 12, 2012 | 07:57 AM
2003corvettez06's Avatar
2003corvettez06
True Ram Air
http://www.wildvettes.com/product_in...roducts_id=165
Old Nov 12, 2012 | 10:07 AM
DARRYLZO6's Avatar
DARRYLZO6
Get the Blackwing, and modify your radiator shroud for cold air and to maximize the performance of the intake. You can pick up one used or even brand new, its going to be a LOT LESS than $500. No quality issues, ease of installation and Ligenfelter uses the Blackwing in theyre R&D of theyre engine packages. You can modify the radiator shroud with a sawzall. Very easy DIY project over the wintertime, and you could pick up a used shroud in case you decide to go back to stock.ITS also very easy to remove and clean/oil. Very happy with the performance results also. And youre still WAY under $500!! Ask me how do I know.
Old Nov 12, 2012 | 10:23 AM
socci's Avatar
socci
Went through this myself and decided to go with the Vararam. Mainly because I found it for a decent price used on these forums, but it was well worth it. Installation was not that difficult as I have heard others state. I read somewhere that the Vararam will give you the best gain while driving, and considering I need it while driving, not idling I pulled the trigger.
Old Nov 12, 2012 | 10:48 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
MODS:
LS3 416ci
Kooks Catted X-Pipe
Old Nov 12, 2012 | 11:56 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Thanks Charlie!
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
Old Nov 12, 2012 | 12:12 PM
ZEE-OH-6's Avatar
ZEE-OH-6
here we go again ......
Old Nov 12, 2012 | 12:17 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Yep, Halltech just made full circle. In 1997, we posted our very first post on Steve Merenkov's C6Corvette forum. Right after our very first post, the first reply was "here we go again" 14 years later.....
We just did the shipping label for the OP.
Thanks for the order.
Jim Hall
Old Nov 12, 2012 | 01:01 PM
dtpugh's Avatar
dtpugh
Default Intake
What do guess think about the halltech killer bee II? I don't care for the vararam, it looks too stock to me with the hood up. So is halltech good?
Old Nov 12, 2012 | 01:35 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
You ordered the Venom II, which is the way to go without tuning and other mods.
GM High Tech and Perf. Magazine tested it at East Coast SC a few years ago. Don't take my word for it:
This was our older Venom intake. (You ordered the Venom II which uses the same huge filter used on the Killer Bee II and Super Bee MF103)
http://www.gmhightechperformance.com...t_on_upgrades/
Old Nov 12, 2012 | 01:56 PM
dtpugh's Avatar
dtpugh
Default Halltech
I do have other mods though, I have MS3 cam, slp longtube headers, borla cat back, and dyno tuned.
Old Nov 12, 2012 | 01:59 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
I would recommend the Killer Bee II in your case.
I can make that change easily. email me at jim@halltechsystems.com to make the change.
Jim
Old Nov 13, 2012 | 02:38 AM
GenerationX1's Avatar
GenerationX1
I run the Halltech Venom with Halltech's HC.125 Honeycomb laminar air flow straightener.
Great product and no check engine lights.
Old Nov 13, 2012 | 02:49 PM
JeremyGSU's Avatar
JeremyGSU
I went with a Vararam.
Old Jun 5, 2017 | 10:35 AM
Georgies's Avatar
Georgies
MODS:
LS3 416ci
Kooks Catted X-Pipe
Whats involved in the installation. I want to buy the killer bee 2 but heard that the engine wont even start if parameters arent changed with hp tuner...??
Old Jun 5, 2017 | 02:12 PM
garrettg's Avatar
garrettg
You would need to buy the new ls3 card style maf and update your maf transfer table to something reasonable which those numbers are provided online by few vendors to just get it to going then for optimal running have it tuned by a pro\neighbor using a wideband and dyno/street tuning. Hp tuners or another tuning programs would be needed just to enter a maf transfer curve to get it going. One option you could do is take your car to your tuner and have them put it into SD mode until then come back with the new hardware installed, or if the tuner will let you install the hardware at the dnyo shop or have the shop install the hardware. Just some ideas.
To Best Cold Air Intake kit?
Old Jun 5, 2017 | 03:04 PM
MY03C5Z's Avatar
MY03C5Z
Performance wise I don't think anything out there beats the VR-B2 when moving at speed. On a dyno I would think some others may outperform it but who races on a dyno, lol.
Old Jun 5, 2017 | 03:06 PM
garrettg's Avatar
garrettg
I would agree with the vararam unless you want to move up to thew new card style maf then the halltech option.
Old Jun 5, 2017 | 10:01 PM
WannaC5Z's Avatar
WannaC5Z
Don't do the Vararam unless you never expect to get caught in the rain. It will be the most likely to suck up water into your intake and vapor lock your engine. There are also dyno studies out there that the Vararam doesn't add any horsepower until around 70mph because the ram air affect doesn't kick in until then. I have the SLP Blackwing and love it. I bought it as a kit with the smooth bellows for the smoothest air flow into the throttle body. Just my .02 worth.
