Clear Corners and Switchbacks installed....
Old Jan 12, 2013 | 03:43 PM
FruiTay's Avatar
FruiTay
Default Hey Toque
Originally Posted by Toque
Looking good ! Always loved your car !
I went with a WHITE LED for the DRL's. Its legal in Texas.
No more yellow for me..... Just nice white light out front...
Where can i order your clear corners? How can I find out if they are legal in Washington state?
You got the crispiest Z brotha
Old Jan 12, 2013 | 03:48 PM
Zr-1Mike00's Avatar
Zr-1Mike00
Originally Posted by Vert'd Z0
So, it took awhile to figure out the best way to get the old lenses out, but after taking my time, here are the results:
I have a set of clear corners and switchbacks to install myself. I have been putting it off for quite a while now contemplating the best way to do the install.... Anyone wanna lend a hand on the easiest way to do so. (I am somewhat mechanically inclined, not sure I wanna take the front clip off though...
Old Jan 12, 2013 | 03:57 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
All I did when I installed mine was raise the front end up, Remove the 2 access panels under the front end and have a ratchet with a good swivel and sockets, It took me maybe 45 mins total.
Mr.Bill
Old Jan 12, 2013 | 04:10 PM
cpaxson's Avatar
cpaxson
Beautiful car, Rich. I just ordered and received a set of the exact same light kit from CorvetteMods, it's great to have a preview of what they will look like.
BTW, what size and make of wheels do you have? And what tires are you running? They fit the car like a glove.
Charles
Old Jan 12, 2013 | 04:37 PM
209TIME!!!'s Avatar
209TIME!!!
looks so much better on a black car for sure...im just a little bias though....lol
Old Jan 12, 2013 | 06:12 PM
Zr-1Mike00's Avatar
Zr-1Mike00
Mr.Bill
Thanks Bill! I'll give it a shot.
Old Jan 12, 2013 | 06:52 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Thanks !
I got my clear corners off Ebay.
I'm not sure where to find out in your state.
I found this link for TX which states that its ok to have "white" front turn signals.
http://www.txdps.state.tx.us/RSD/VI/lighting.htm
Click on - Clear Tail Light Lenses... then scroll down to turn signal.
Hope this helps
Toque
Old Jan 12, 2013 | 06:56 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Mr.Bill
Mr. Bill - so you have amber LEDs behind the front corner clear reflectors correct?
Old Jan 14, 2013 | 02:08 AM
Mr31FlavorsVette's Avatar
Mr31FlavorsVette
St. Jude Donor '12
My son purchased mine from Corvette Mods as a recent Christmas gift. We just installed them tonight. Did it the same way as Mr. Bill, the big PIA was the brake air duct. The LED switch backs work great. The problem now is they make my stock headlights and fog lights look ancient. So I guess I'll be upgrading both, however, I'm looking just for LED bulbs and not a HID conversion to replace my fogs. As for the headlights, I'm looking at Corvette Mods Projector Lens and HID conversion, as well as RadioFlyer's Bi-xenon ACA Projector Headlights. Still a little confused on the best way to go on the headlights.
Old Jan 14, 2013 | 02:16 AM
MotoJB's Avatar
MotoJB
Very nice...looks better
Old Jan 14, 2013 | 02:52 AM
corvettemods1's Avatar
0corvettemods1
Former Vendor
Call us Monday, our projectors are on sale and we can get you all set up!
Old Jan 14, 2013 | 03:58 PM
Vert'd Z0's Avatar
Vert'd Z0
Charles
thanks Mr. Bill, Toque (high praise, indeed), Charles and the rest.....
Neil as well as the other vendors ive dealt with here are top notch.
a friend of mine is about to pull the trigger on the entire setup as well
after seeing mine.
as for the install, i went the way Mr. Bill posted.....didnt have to raise the car, but prolly wouldn't have hurt lol. i removed the corner air dam pieces and the access doors (seven 7mm screws/side IIRC) and reached up in the cavity. since the car is so low, i had to just "feel" my way around, but there are two other 7mm screws near each end of the lens that need to be removed, 1/4 turn the bulb connectors from the lenses and then remove the lens. reverse the process and your good to go.
one thing i WILL mention re: the switchback bulbs is you have to fully seat them into the sockets. after i took the posted vid, the passenger side was acting intermittently and i had to take them back out to check. i noticed on the driver's side that the bulb was "farther" in to the connector. so i tried the original amber bulb and noticed it seated farther into the connector as well. so i reseated the pass. side, giving it a little extra "push" and they've been flawless since.
as for wheels, Charles, they are CCW T-10's (John, Chip, Melissa, etc. are another great vendor), 19 x 10 and 20 x 11's wrapped in Michelin PS2's, 275-30-19's and 305-25-20's.
good luck and post pics.
rich
Old Jan 14, 2013 | 04:13 PM
  #33
Mr31FlavorsVette
St. Jude Donor '12
Actually, I had a 10mm on one end of the light and a 7mm on the other end that had to be removed to extract the whole light assembly. There is also a spring at the top that has to be removed, but don't take it off where its connected to the front fascia. Makes it easier when reinstalling. Also, to remove the bigger of the two bulbs, you have to squeeze a plastic clip while turning the bulb.
I had the same thing happen to me, if you don't push the Led bulbs in all the way, and its hard to do while you're laying under there, the bulb would light up white, but not switch over to amber with the turn signal on.
Old Jan 14, 2013 | 04:24 PM
  #34
Mr.Bill's Avatar
Mr.Bill
That is correct.
Old Jan 14, 2013 | 08:55 PM
  #35
GCG's Avatar
GCG
...one thing i WILL mention re: the switchback bulbs is you have to fully seat them into the sockets. after i took the posted vid, the passenger side was acting intermittently and i had to take them back out to check. i noticed on the driver's side that the bulb was "farther" in to the connector. so i tried the original amber bulb and noticed it seated farther into the connector as well. so i reseated the pass. side, giving it a little extra "push" and they've been flawless since...
take a look at this thread where this problem is discussed with more details and pictures. Scroll down to post #9
Old Jan 15, 2013 | 02:38 AM
  #36
B747VET's Avatar
B747VET
Thanks for the great pics and the detailed explanations. You've sold me! Tremendous upgrade even when shut down in daylight. Great car!
Old Jan 15, 2013 | 08:03 AM
  #37
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Nothing new or earth shattering, but I've been wanting to do this mod for awhile now and so I decided to contact Neil @ Corvette Mods and order a set of all clear corners and switchback and parking light LEDs to go along with them. I know there are a lot of good vendors on here and I've done business with a few of them and have really never been dissatisfied with any of my experiences. And to date Neil and his company have been great from ordering to delivery in every instance.....thanks, Neil.
As delivered:
Left/Right before:
Left/Right after:
and a short vid showing them in action:
Also ended up going to the Good Guys Autumn GTG in Pleasanton this past weekend and took a few shots. Keep in mind, i have NO eye for good photography :
Thanks for taking a look......
Rich
That's one sweet looking ride.
To Clear Corners and Switchbacks installed....
Old Jan 15, 2013 | 02:22 PM
  #38
GCG's Avatar
GCG
Nothing new or earth shattering, but I've been wanting to do this mod for awhile now and so I decided to contact Neil @ Corvette Mods and order a set of all clear corners and switchback and parking light LEDs to go along with them...
Very nice! What did you do to correct LED hyperflashing? Did you install a hyperflash harness?
Old Jan 15, 2013 | 03:14 PM
  #39
z06Freshhh's Avatar
z06Freshhh
Very nice! I thought i only liked the stock look im on the fence now!
Old Jan 21, 2013 | 03:03 PM
  #40
B747VET's Avatar
B747VET
I just ordered the lights, lenses, and resistors on Friday from Corvette Mods. My understanding is that the front turn signals may be either yellow or white in California and that the DRL's may be white or yellow, but that the front side marker lights MUST be yellow.
My desire is for a California legal bulb system that looks like Mr Bill's above. White DRL's, white or yellow front turn signals when activated, and that yellow front side light that makes it all legal.
Also, is it possible to charge me extra for overnight arriving in Calif by Mon or Tues?
Many thanks...
