Exhaust flames
Firstly, those effects are achieved by installing tiny fuel lines into the exhaust tips which are illegal for obvious reasons.
Spark plugs cannot ignite what isn't there. You'd need to be running extremely rich to have ignitable fumes in your tail pipes. And if that were the case, you wouldn't need any ignition source to have flames backfiring out of your tailpipes. You would have a lot more serious problems to deal with.
Glad you found a way to have fun, and was surprised that a kit was available. What a country.
I guess it's got to be "hot rod" if it ticks people off and I have always liked hot rods.
Good luck, don't get too hot . All that plastic...............and gas.
Yes it can be done with good results, But here in the States a Corvette is respected, It is the Great American Sports Car.
We use to do that stuff back in the 50 and the 60s to our beat-up hot rods, But not to a Corvette.
It is your car and you can do as you like.
Where are you located?
Good luck on whatever road you take.
Mr.Bill
And I, too, will level with you, as you asked.
It's adolescent beyond belief; it's Clearasil, Speedos, gold chains, drinking cheap beer until you puke...it's silly.
It's also dangerous. Have you ever seen a Corvette melt and burn?
However, many of us "over here" were adolescent, and silly, once ourselves. I seem to recall a certain '49 Ford Tudor, 3 speed, flathead V8. At that time you could buy from a craphouse supplier called "J.C.Whitney" a "kit" to throw exhaust flame when you energized a coil attached to a spark plug stuck in the exhaust pipe. "For best results" the instructions mentioned to enrich the mixture. If a little is good, a lot must be better. We twisted the mixture needle on that old Stromberg 97 until it was about to fall out: fired it up, stood on the pedal to keep it running, hit the coil switch...and blew the entire exhaust system to heck and back. And caught the front yard on fire.
Go ahead, enjoy yourself. Too bad about the 'vette.
Best Regards, and, Go Manchester.
Gunny John
PS. For guidance on these and other matters, just ask yourself...WWWD?
(What Would Winston Do?)
You get a couple of model "T" coils and a couple of spark plugs, wire the coils up to a switch that will stay energized with the engine ignition turned off.
Turn on the "T" coils and the plugs will fire steady in the exhaust.
Start the car.
The way you keep the fuel going into the exhaust, is to keep flooring the gas at the same time as you turn the engine off and on with the key rapidly, keeping it just barely running, causing raw fuel and air to flow down the exhaust, once you get going into a kind of rythm, the flames get bigger and better.
Now you know, and now for the down side.
Your gas washing the cylinder walls, don't expect the engine to last doing this.
Seriously contaminating the oil with gas.
Stall the engine, and risk blowing the exhaust apart, or blowing the oil pan off.
Wearing out the ignition key and switch because of all the rapid back and forth.
Accidentally stalling the engine while mid flaming, possibly burning the car to the ground.
You don't need fuel lines running into the exhaust anywhere, way too dangerous.
I did this many times with fifties cruisers years ago, and it was a blast, but you didn't do it with an engine you cared for, or valued.
Good luck, get yourself a good fire extinguisher!
