I noticed a fine scratch on the trunk of my car. It is very fine, but if you run your finger nail over it you can feel it...drives me crazy it's about 3 inches long. Any suggestions would be appreciated.
First try using a premium car car swirl and haze remover product. I use Adams. Use it with a orbital buffer to see if you can get the scratch out.
If no, try wet sanding the area with 3000 or 2000 grit sandpaper and follow-up with some rubbing compound. You may have to go lower than 2000 if the scratch is deep. After the scratch is removed, follow up with a polish and wax.
Be careful not to go all the way through the clear coat.
Before you sand, see if you can apply some "colored wax" on the area. This can work for light scratches. Once applied, remove it so the colored wax remains in the scratch area. Let us know how it works out which ever way you go.
there is also a compound made by 3m. they have a 3 stage compound. As said before it isnt hard to cut thru the clearcoat then you have to sand bend the paint then clearcoat the entire panel. So i would try a cutting compound to try and buff the scratch out as it isnt as hard to buff thru a panel as sand thru it ...BUT! you can buff thru it also if you buff to much you will burn thru the clear as well.
If you do decide to try and sand and you think you can go with the advice already stated. wet sand with say 1200 or 2000 then follow up with 3000 then buff it out but again dont get too agressive or you will cut thru
^^^ I prefer this method. Buff before wet sanding. Start with a foam polishing pad and cutting polish. If that doesn't work, try a lambswool pad and rubbing compound. Keep the RPMs at or around 300. Wet sanding should be an absolute last resort.
