Katech tensioner
Old Nov 15, 2012 | 12:30 PM
clegg's Avatar
clegg
Default Katech tensioner
I was having a lot of serp belt chirp issues. I bought a Katech tensioner and a new Gatorback belt. The belt chirping is gone, but now I have a resonance coming from the tensioner. At first I thought I had driveline noise, but upon checking its isolated to the tensioner. I installed it to Katech specs.
Anyone else have this issue?
Old Nov 15, 2012 | 12:34 PM
LoneStarFRC's Avatar
LoneStarFRC
None.
Old Nov 15, 2012 | 12:45 PM
PhilsFRC's Avatar
PhilsFRC
No issues here. Did you overtighten the belt? Katech recommends a specific ft/lb tension to be pulled before the tensioner is locked down.
Old Nov 15, 2012 | 01:04 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
What did you tension the belt to?
__________________
Contact:
(e) zach@katechengines.com
Old Nov 15, 2012 | 02:16 PM
clegg's Avatar
clegg
25 ft lbs
Old Nov 15, 2012 | 02:21 PM
Katech_Zach
25 ft lbs
You did it right. Does the bearing in the pulley feel okay? They rarely go bad if not over-tightened, but it's possible.
Old Nov 15, 2012 | 02:38 PM
clegg's Avatar
clegg
It seemed OK when I took the belt loose to check everything. I suppose that it does not have a timken bearing in it?
Old Nov 15, 2012 | 03:35 PM
Katech_Zach
I don't know much about the bearing. We buy the pulley/bearing as an assembly from an OEM pulley supplier.
Old Nov 15, 2012 | 04:09 PM
PhilsFRC's Avatar
PhilsFRC
Check to make sure the tensioner is aligned with the plane of the other pulleys. It's possible (remote) that you'd have to shim it due to other tolerance stacking errors.
Old Nov 15, 2012 | 05:23 PM
clegg's Avatar
clegg
No, it's aligned.
Old Nov 15, 2012 | 05:52 PM
PhilsFRC's Avatar
PhilsFRC
OK-for yucks and chuckles put the old belt back on or alternatively get a standard GM belt and see what happens. If it disappears it's the Gatorback belt-my last and best guess.
Old Nov 15, 2012 | 05:59 PM
PhilsFRC's Avatar
PhilsFRC
Default P.s.
I'm a firm believer in the "what's changed?" school of thought. You changed two things-tensioner and belt-and created a new problem. Basically it's one or the other part-or both.
Old Nov 15, 2012 | 06:05 PM
clegg's Avatar
clegg
No it's definately the tensioner.i reinstalled the old auto tensioner with a new idler and quiet as a mouse now.
Old Nov 15, 2012 | 06:19 PM
PhilsFRC's Avatar
PhilsFRC
Get with Jason-maybe you got a bad part-happens. Glad you solved your dilemma.
Old Nov 16, 2012 | 04:57 PM
Katech_Zach
Sent out a new pulley today under warranty. They rarely go bad if tensioned properly, but you never know if you got a bad one out of the bunch.
Old Nov 16, 2012 | 05:03 PM
clegg's Avatar
clegg
Thanks Jason, great service.
To Katech tensioner
