2000 corvette going into safe mode
Old Nov 18, 2012 | 12:53 AM
scarolina's Avatar
scarolina
Default 2000 corvette going into safe mode
My 2000 corvette has 3 inch long tube headers, off road x pipe, and no cats. While driving down the road or starting off from a stop light the car will suddenly go into safe mode and not want to run no matter how much gas I give or anything. I have already replaced the plugs, triple checked the gapping, changed the plug wires, air filter, fuel filter, checked the coil packs, did a compression test on all cylinders, replaced the front o2 sensors, checked for any air leaks, cleaned the maf sensor. Can not fix problem. Im getting these codes when I read it out PO174; PO152; PO131; PO132; PO300. Any help would be awesome. Could it possibly be a bad accelerator pedal sensor??? Or a bad ECU needing to be reproggramed from having no Cats on the car??? Car wont even sit in driveway and idle properly. Wants to stall.
