HID resister value?
Old Nov 23, 2012 | 10:05 AM
Phanni's Avatar
Phanni
Default HID resister value?
Who knows what ohm resister is needed for the for HID installation to allow headlights to retract without going to high beams? My vert has HIDs with the resister installed, and I'm going to put them in my coupe soon and I'd like to build my own resister 'package'.
Old Nov 23, 2012 | 11:53 AM
Phanni's Avatar
Phanni
anyone?
Old Nov 24, 2012 | 12:31 AM
TNX ZORA's Avatar
TNX ZORA
When I went to HID and needed to insure the headlamps reliably opened and closed I found that a 200 Ohm resistor would do it. Naturally a lower value would also work but will generate more heat and thus need to be higher wattage. The 200 Ohm resistor I used looked to me to be about 2W. It was tubular so wattage wasn't marked.
Old Nov 24, 2012 | 09:38 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Resistors would only be needed with 35w HID kits since the factory wattage is 55. Check your ballast for it's power rating.
Old Nov 24, 2012 | 04:12 PM
Baibaikin's Avatar
Baibaikin
resistors get scorching hot. I have one that came with the HID kit and that one is encased in brass heat sink, and those things will do some branding on the skin. You would be doing some cooking/melting if you don't do it right.
Old Nov 25, 2012 | 08:55 AM
Phanni's Avatar
Phanni
Thanks forthe replies guys.
To HID resister value?
