Ambient Light Sensor - MIA
I've had this code BCM B2647HC, since I bought the car a couple of months ago. '99 coupe
The car is now put to bed for the winter and I'm looking into a number of things that need tweaking!
Looked through the wind-shield at the centre grill; and low and behold there it was, "gone".
That's right; no sensor, just a hole in the grill! So it obviously fell off at some point in time.I had already taken off the accessory trim to pull the hvac control and fix the low light issue. I love inexpensive repairs! Solder and reassemble!!
So, I know someone else must have seen this ambient light sensor issue. Will I be able to find the missing sensor misplaced once I remove the accessory trim plate, a second time?
Thanks in advance.
Dan
I was hoping to to see a photo before I check it out this weekend.
Dan
