How do I get the check engine code #?
Old Dec 2, 2012 | 04:45 PM
FruiTay's Avatar
FruiTay
Default How do I get the check engine code #?
I got the light on, just need to know what the problem is, don't know how to get code to pop up. Can anyone help? Thanks guys.
Old Dec 2, 2012 | 05:03 PM
Phanni's Avatar
Phanni
key on engine not running.
hit reset.
push options and hold
hit fuel 4 times
the codes will cycle through automatically
It's best to have someone write them down while you read them out.
Old Dec 2, 2012 | 05:14 PM
GK's Avatar
GK
hit reset.
hit fuel 4 times
Mynewluv,
This video will help as a picture, or in this case, video's say a thousand words.
Old Dec 2, 2012 | 07:50 PM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
And here'd what the codes mean:
http://www.stengel.net/diccodes.htm
Good luck.
Old Dec 2, 2012 | 08:30 PM
FruiTay's Avatar
FruiTay
Default You guys are great!
P 0140 is my current code. I have already replaced the vacuum hose from the AIR pump along the wheel well and to the manifold. I have also had both ceck valves replaced. I'm gonna do some searching now. Maybe I'm a victim of battery acid...
To How do I get the check engine code #?
