[Z06] clutch replacement
Old Dec 3, 2012 | 12:30 AM
blueku's Avatar
blueku
Default clutch replacement
I live in calif fresno and was wanting to know if anybody on this forum could tell me if there is a resonable shop in town to change the clutch, or about what it would cost to have the work done, labor only for I have purchased the clutch flywheel and slave already. Has anybody used the grip force stage 3 clutch with the ceramic pads? have a stock z06, the clutch is rated for 550 hp hope its not to much clutch. thanks can't wait to here your input!
Old Dec 3, 2012 | 01:20 AM
striper's Avatar
striper
By already purchasing your own clutch you are limiting the places might do a clutch swap. Most shops will want to sell the brand they are familiar with using and are comfortable standing behind should there be a problem.
When I was young my father owned a service station that also did drag race performance work. He had a poster that said you don't bring your own ham and eggs to the diner and ask them to cook them. Then don't bring your own parts here. Just a suggestion.
Old Dec 3, 2012 | 01:45 AM
FourG63 97GST's Avatar
FourG63 97GST
I think you'll hate the clutch personally, it's overkill for a stock car for starters. And puck style clutches just are annoying. $1500 later, you'll wish you spent the extra $300 for a full face twin disk.......that being said, clutch install usually go for $700-$1000. And get a remote bleeder also. It's a must on these cars, I know it's human nature to learn the hard way,so good luck
Old Dec 3, 2012 | 08:23 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I don't think I could charge more than 600 for a standard clutch install
May be best to drive up to the Bay area, one of the forum sponsors that has done 100 plus of the swaps
Old Dec 4, 2012 | 10:41 AM
blueku's Avatar
blueku
Thanks for your replies, talk to the mechanic I use he gave me an estimate of 850.00 to replace the trannie rear seal the drive line gasket to the rearend and fix the oil leak on the engine pan, either the front or rear seal and install the clutch is that good?
Old Dec 4, 2012 | 11:36 AM
Paul 75 L82's Avatar
Paul 75 L82
I bought the parts and paid a very good local Corvette shop $1000 for the install. That also was installing new couplings in the Torque Tube.
To clutch replacement
