trying to fit c6 wheels
Old Dec 9, 2012 | 12:18 AM
Amixamse's Avatar
Amixamse
Default trying to fit c6 wheels
i boiught this set of c6 wheels off my friends camaro because there was no way of fitting them without modding which he doesnt like to do. the rear tires are 325/30/19 and wouldnt fit on mine either. i just ordered a 1.25" spacer for rears. is that all i need??
Old Dec 9, 2012 | 01:18 PM
Amixamse's Avatar
Amixamse
Bump
Old Dec 9, 2012 | 02:49 PM
CQRT's Avatar
CQRT
I searched the general as well as technical forum as I assume you have, and there's not a heckofa lot- leading me to think that what you're contemplating is no big deal. For a long time, I seem to recall the general knowledge that 'C6 wheels fit on C5s with an inch spacer' - - if it's slightly larger, I didn't remember that part.
The only thing I'd be cautious about in the length of the lug - - one post I read advised that any spacer larger than 1" should use longer lugs- but don't accept that as gospel.
I'm sure there will be more input over the next couple of days- please post any other findings you might discover.
Good luck
Old Dec 9, 2012 | 03:02 PM
dblerman's Avatar
dblerman
Stock C6 rims will fit without issue or modification, but will look better and sit flush with the fender with 1/4" spacers in the rear.
I think the issue you're having is the fact that your tires are 325 width. If those are factory c6 rims, that tire is WAY too wide.
Old Dec 9, 2012 | 03:59 PM
Amixamse's Avatar
Amixamse
It's a 19x10 a 325 isn't pushing it right?
The spacers are the ones that have studs built in..
Old Dec 9, 2012 | 04:10 PM
dblerman's Avatar
dblerman
Yes, 325 IS pushing it on a 10" rim. Most tire manufacturers list a minimum of 11.5-12" width for their 325 tires. If you want to run a wide tire, do it right and get wider rims. Not only that, but having your wheels stick out an inch past your fender is going to look like crap.
Old Dec 9, 2012 | 09:50 PM
Amixamse's Avatar
Amixamse
It doesn't look stretched. If the tire pokes a little I'm good with that I like big booty vettes
Old Dec 9, 2012 | 10:17 PM
dblerman's Avatar
dblerman
It's not going to look stretched, if the tire was too narrow for the rim it would look stretched.
Old Dec 10, 2012 | 06:49 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
A 325/30/19 tire needs a 12 to 13 inch wheel.
Get new wheels or new tires.
Mr.Bill
Old Dec 10, 2012 | 10:34 AM
Dudeurgettnavette's Avatar
Dudeurgettnavette
should fit with out a problem
Old Dec 10, 2012 | 01:27 PM
Mike Mercury's Avatar
Mike Mercury
I used 1/4" plate spacers on the rears; fronts have the same offset on both the C5 and
C6 and didn't need any spacers.
You don't have to run spacers on the rears either; but it will look kinda weird.
No issues with over 5k miles.
Old Dec 10, 2012 | 01:48 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
I think your referring to adapters and not spacers. If the studs are already built you should be good to go.
Old Dec 10, 2012 | 02:26 PM
Amixamse's Avatar
Amixamse
Well i talked to the guy who rode on these on a built 6 speed Camaro he said he never had any problems with the 325.. As soon as the adapters come in I will post pics. I think it will look good
Old Dec 10, 2012 | 03:29 PM
dblerman's Avatar
dblerman
Just because he "never has any problems" doesn't mean it's the correct tire for that size rim.
Then again, you also said there was no way he could fit them on his camaro without modding
Old Dec 10, 2012 | 04:24 PM
corvettepete's Avatar
corvettepete
I wouldn't push it. I installed rear 19 x 10.5" Cray Scorpions on my '99 coupe last spring. Cray along with my tire folks both said not to go wider then 305 tires with the 10.5". A perfect fit, BTW.
Old Dec 10, 2012 | 07:24 PM
Amixamse's Avatar
Amixamse
1 original guy w Camaro that made them fit
2 my friend I bought them from that never got em to fit on his Camaro.
Old Dec 10, 2012 | 07:42 PM
James2002z06's Avatar
James2002z06
I remember when I was new on here , and like this one here , you had to set me straight more than once ... My I chin in here I cannot believe that you have a 325 on a 10 in rim . Please take these guys advice .... That tire on that rim is not good man , just sayin
To trying to fit c6 wheels
Old Dec 10, 2012 | 07:44 PM
James2002z06
He has a 325 on a 10 inch rim !
Old Dec 10, 2012 | 08:29 PM
Amixamse's Avatar
Amixamse
I hear you guys gotta get a different tire I will take it easy on these till I can afford some new ones...
What's the worst that could happen? Can the wheel actually spin without tire spin? Lol
Old Dec 10, 2012 | 08:40 PM
James2002z06
It could destroy the side of your car, I have no room to talk I have a 12 inch tire but on a 12 inch rim [/IMG]
