I don't want to be fast anymore
#121
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
'02 Honda CBR-954RR
Bro, the Beretta has been with me for a while. Thanks for the compliments on the house. I just won a nice large settlement(rather not talk about it, it's a bit embarrassing) so I treated myself to some toys. I have some shots of it next to my vette in the garage I can post later when I get home if you don't believe me.
I don't understand why this is so difficult.
#122
Received 2,720 Likes
2018 C5 of Year Finalist
Beastly, no offense but its hard to take this seriously, so let me tell you why....the first pic you posted shows you in front of a decent house in what looks to be a decent neighborhood, you have a nice clean vette with an motorcycle in the background, yet you also have what looks to be a crappy beretta that doesn't look like it has Illinois plates, and it's in what looks to be a "shady" part of town, so I see flaws everywhere. Just find it hard to believe your gripping about gas mileage while living in good place with multiple vehicles....BTW, what kind of bike is that in the garage?
Personally, I think this is the same troll that started the thread about getting jumped in the parking lot while donating used cell phones...
#123
1 Post
So if you disconnect your spark plug wires on four cylinders, what will happen is you will flood your exhaust with unburned fuel. The fuel will ignite in the exhaust causing combustion in your exhaust. Your exhaust will start glowing red, including the exhaust manifolds and your catalytic converter will melt, and the heat will start damaging wiring that is around your exhaust manifolds.
This is what happens whe just one coil stops firing your spark plugs. Mutiply it time four it should be a real melt down.
Great plan!
Great plan!
#125
The 2.8L isn't much better:
http://www.automobile-catalog.com/ma...etta/1989.html
18 city/29 highway, with a blazing 16.9 1/4 mile time!
Basically exactly the same estimates as the C5 Vette (minus the 1/4 mile time, of course).
#126
#129
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It is a sad day on Corvette forum, I can't believe how many people take this guy serious, He just joined up and I would be willing to bet he doesn't even own a Corvette.
There is no way this guy can be serious and you guys took it hook, line and sinker...lol
Mr.Bill
Mr.Bill
#132
AKA "The CLOWN"
Hey OP where do you live in IL. I will be more than happy to come take a look at your car to see why you are getting bad mpg!
If this is not a joke?
I'm being serious! Let me know!
#133
BeastlyC5,
I have been off the forum a while. Today I got back and came across your thread here and find some of the replies worthy of deletion by the moderator. I am sorry you are left to respond to them.
Now to your question, and my thoughts about taking a cylinder or two off line.
Simply Said.....DON'T do it. This is why.
Any vehicle that was engineered to take cylinders off line for fuel economy is controlled with software and sensors to assure a consistent engine block temperature across the entire block. Different cylinders get turned off and on for even block heating. If a cylinder is permanently shut down, that part of the block will remain cooler than the active cylinders around it. This will set you up for permanent damage, either to the engine block, the engine heads, or both. Damage will come in the form of warpage or cracks in the metal with supporting gaskets unable to do their job right and then failing themselves.
Regular every day vehicles will suffer similar damage if a spark plug or ignition to a particular cylinder has failed and left unchecked for an extended period of time.
If you absolutely insist on experimenting, then I advise the following, and I wish you the best of luck with it.
1) The 2 cylinders selected for shut-down should not be in any of the 4 corners of the engine in hope the dead cylinder in-between two active ones would be kept hot enough to reduce the risk of engine or head warping as compared to a corner cylinder which is thermally isolated.
2) The dead cylinders should not be directly across from eachother for the same thermal reasoning. You want "Even" heat distribution.
3) The firing order should be 3 active - 1 inactive in repetition. I have not studied the C5 engine firing order and cannot confirm this is even possible if shutting down 2 of the 4 inner cylinders diagnally.
4) Shutting down a piston should simply involve removing & insulating the connector to the supporting fuel injector, nothing more than that. Do NOT remove the spark plug because some amount of engine oil will spray out and onto the hot manifold near by. This will cause an engine fire. Also, if you don't unplug the injector, you are not saving any gas. It still sprays the same amount of gas into the combustion chamber, doing nothing more than putting a lot of raw gas into your exhaust system, destroying your catalytic convertor and more.
Understand that your engine monitoring system will light up your dash board, indicating engine trouble. If your state requires emissions testing, you will surely have to put things back to original and clear engine codes before testing.
Again, I highly recommend you don't shut down any cylinders, but if you insist on taking a risk, try to follow my advise.
Well wishes....I hope you don't destroy your Corvette.
Ron
Ron
#136
#140
I personally don't think this thread should get banned...if anything it's entertaining as hell, but on a more serious note, taking away a few cylinders reminds me of how Mustang Special vehicle Operations team made the Mustang SVO from 84 to 86. It was an attempt to combine v8 power with fuel consumption of a 4 cylinder. Still one of my fav cars.
