Help
Old Dec 13, 2012 | 08:47 PM
BigD61960's Avatar
BigD61960
Navigator
Default Help
First vette. Won't turn over, disconnect battery and will will start
Old Dec 13, 2012 | 08:56 PM
Jistari's Avatar
Jistari
You probably have to give us a little more info.
What happens when you turn the key?
Does the engine crank?
What do you hear?
Do you see any messages on the DIC (the small text display directly over the steering wheel)?
In general:
You've checked the connections?
The cables are tourqued to 22 ft lbs.?
Have you put a meter across the terminals with the negative lead disconnected to see the voltage the battery shows? (btw you cant leave it connected and look at the voltage reading on the DIC thats not gonna be accurate)
Have you charged the battery? (this car is pretty sensitive to battery voltage, probably a lot more than any other car you've worked on. A whole bunch of systems have to wake up and check in on the bus in the right order for it to not give you headaches) so before you do anything else start with a fully charged battery to limit the ancilarry problems.
Good luck
Old Dec 13, 2012 | 09:06 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Now how can you start it without a battery?
Old Dec 13, 2012 | 09:17 PM
BigD61960's Avatar
BigD61960
Navigator
After i reconnect it it starts. Only code that comes up is p1214
Old Dec 13, 2012 | 09:21 PM
cor28vettes's Avatar
cor28vettes
So what's the problem?
Old Dec 13, 2012 | 09:31 PM
BigD61960's Avatar
BigD61960
Navigator
Almost every day it won't start or even turn over. Have to disconnect and reconnect battery to start
Old Dec 13, 2012 | 10:17 PM
Mickeyrx70's Avatar
Mickeyrx70
First thing I'd check is the cables & make sure they're not shorted out somewhere. By disconnecting & reconnecting you could be temporarily fixing a short.
Old Dec 13, 2012 | 10:25 PM
cadmando18's Avatar
cadmando18
How does the battery tray look? Does it look really bad, corroded? How do your cables look? Start with simple stuff... clean your battery terminals... and sorry if you've already done this. Working with very little info.
Old Dec 13, 2012 | 10:44 PM
sonny557's Avatar
sonny557
Default Starter
May be they wire going to the starter is loose and making contact when you remove and replace the battery cable,,,,,,,dont know!
Old Dec 15, 2012 | 11:58 PM
cor28vettes
see Bill Curlees pic
http://forums.corvetteforum.com/show....php?t=3166195
then add your final (related) fix please
http://forums.corvetteforum.com/show....php?t=3183336
To Help
