Sticky 1st gear
Old Dec 14, 2012 | 10:37 PM
ebatters's Avatar
ebatters
Default Sticky 1st gear
2001 6sp. When at a stop in nuetral - often hard to get 1st gear - feels like its obstructed....about 50% of times. Have tried going back into 2nd then into 1st but no diff. If I try to go in a hurry ( light changed and I was distracted...gear will grind) Not an issue when rolling downshift. Fluid has been changed twice. No other issues shifting. 78K miles Likely original parts. Any ideas/pointers to cause appreciated?
Old Dec 15, 2012 | 02:57 AM
GenerationX1's Avatar
GenerationX1
Mine is the same way in my C5Z and it gets on my nerves at times.
I have 53'000 on mine.
Old Dec 15, 2012 | 07:18 AM
nmacdonald's Avatar
nmacdonald
If you follow this thread and look at Bill Curlee's advice, you may find some help in resolving your issue.
http://forums.corvetteforum.com/c5-t...ing-wrong.html
Old Dec 15, 2012 | 08:26 AM
MSUGTO's Avatar
MSUGTO
I had a similar problem where 1st was a bit tricky to get into, after I changed the transaxle fluid it got tons better. When was the last time it had been changed?
Old Dec 18, 2012 | 12:35 AM
ebatters's Avatar
ebatters
Trans fluid was changed recently...no change oted
Old Dec 18, 2012 | 12:43 AM
ebatters's Avatar
ebatters
Thanks for the Bill Curlee thread....I'll be out of the country for a while but the car will be getting several upgrades and I'll provide this info to the mechanic taking care of it. It will take a while but I will report results
thanks again
To Sticky 1st gear
