I don't have one fitted now and the previous (only) owner never mentioned that a Lojack had been fitted. I guess I could call him if he is still around.
Thanks for that confirmation about the gray devices being original - I guess I should investigate the yellow connectors. The wires coming from them appear to be cut and taped off.
To be honest, I can see more clearly in the photo, than on my knees with a flashlight in the passenger footwell!!
The two gray boxes are part of the serial data bus. This is part of the cars wiring.
Gary's right. They're called "star" connectors, essentially connecting numerous subsystems to the data bus. The yellow connectors are definitely not original--dunno what they are.
Those yellow connectors look like fuse holders or something like that... do you have an aftermarket stereo or some kind of similar aftermarket item on the car?
Thanks for all the info, guys - will investigate and get back with result. May be a day or two as it's a bit of a squeeze getting head and both arms into the footwell
