Auto with 3.42 mpgs?
Old Jan 4, 2013 | 12:59 PM
jerrad's Avatar
jerrad
Default Auto with 3.42 mpgs?
I recently had my t56 pulled and went with an rpm built 4L60E along with a 3200 stall. It looks like my mileage is cut in half. The car has LT's, no cats, A&A, custom tune, etc. I've been doing all city driving while just cruising, no WOT runs. I just filled up and I only avg'd 12.7 MPGs. I was around 16-18 in the city with the t56. Do the numbers add up or do I need to have my tune looked over?
Jerrad
Old Jan 4, 2013 | 01:17 PM
onlyavette's Avatar
onlyavette
Probably due to the converter more than the gear ratio.
Old Jan 4, 2013 | 01:38 PM
The change in rear gearing should not drop your MPGs that much. But your mileage can vary with each fill-up depending on a lot of factors - traffic patterns, route taken (hilly, lots of stop lights, etc.), and the weather. I'd check the MPG for a couple of more tanks before deciding that something is wrong. Another thing to consider is a manual tranny car typically will get better gas mileage than an auto tranny - at least my '00, which was a 6-speed car, got better MPGs than my '03 A4 car gets.
Old Jan 4, 2013 | 02:11 PM
2001yellow/redC5's Avatar
2001yellow/redC5
Jerrad
I have almost the same setup (local tuner) and I am getting 19 mpg around town and 27 mpg on the Highyway. FYI I changed my original (1998) o2 sensors out and picked up 1 mpg.
Old Jan 4, 2013 | 04:31 PM
robert miller's Avatar
robert miller
To the OP here I wish I got 12.7 in town with my auto and 3:42 rear gear.
Old Jan 4, 2013 | 04:33 PM
jerrad's Avatar
jerrad
I'm on a SD tune so my o2s aren't in play.
I'll do a few more tanks and see where I'm at.
thanks everyone
Old Jan 4, 2013 | 04:34 PM
RonSSNova's Avatar
RonSSNova
My cam, heads etc A4 with 3600 stall and 3.42 gets 14mpg in typical stop and go driving. On weeks where the traffic is light, that goes up to 16mpg. My commute is 90% freeway, but at least half the time it's a parking lot.
MPG on the highway at 73 mph is 25.
I'm not fully tuned yet, the DFCO (decel fuel cutoff) is still turned off.
In stop and go, the converter is what sucks the mileage down.
BTW....these readings are from the DIC which has proven to be quite accurate.
Ron
jerrad's Avatar
jerrad
Haha, I wont whine too much.
Old Jan 4, 2013 | 05:16 PM
jerrad's Avatar
jerrad
Ron
My dic was saying 15.
guess I'm not too far from the norm.
Old Jan 4, 2013 | 05:48 PM
Jistari's Avatar
Jistari
Do they change the gas to E10 or whatever at this time of year by you?
Old Jan 4, 2013 | 06:28 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Don't forget too that the Automatic has a much lower overdrive ratio than does the M6. It's significant. Not only does the motor twist more, but it does it at a point where fuel economy is terrible. My A4 car (w/3.15s) gets about 4-5mpg more at 60mph than it does at 75. First car I ever owned where that was the case. I'd almost say my M6 car is opposite. Maybe not 4mpg, but close.
To Auto with 3.42 mpgs?
