squeaking noise
Old Jan 12, 2013 | 07:25 AM
User 020415's Avatar
User 020415
Default squeaking noise
00 C5 with 98k
Rear squeaking noise that's driving me up the nuts, just getting in and out of the car it squeaks, after couple of shops looking at this, both of them scratching their head, then spending hundreds of dollars of replacing upper arm control and gotten no where fast, is it the shocks, the end link? other bushings? Please advice!
Old Jan 12, 2013 | 12:21 PM
Phanni's Avatar
Phanni
It could be your bushings for the rear sway bar.
Old Jan 12, 2013 | 12:46 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
00-C5, 88k miles, C5-Z06 Sway Bars, C6-Z06 shocks.
Just had the same problem. New Poly bushings for the rear sway-bars, took them down, re-greased them, and so far all is good. If you have metal end links on your sway bars that shouldn't be the problem, seems like lots of guys have the problem with greasing the bushings on the sway bars. Check that out....
I was told to use this:
Old Jan 12, 2013 | 01:08 PM
dmarkshark's Avatar
dmarkshark
Where did you get the Super Lube. I've looked around here once in a while but haven't seen it.
Old Jan 12, 2013 | 02:52 PM
RC000E's Avatar
RC000E
I went crazy tracking this type of noise down and it took me putting the car on the lift 5 times to find it. I found mine when I loosened the lower shock mounts, releasing the compression of the bushing...instantly gone! I then loosened the lower shock more, used a pry bar to push the lower mount sideways and lubricated the bushing face, the moved it the other way and did that side...not a noise since.
With mine it just came out of nowhere one day. Check the lower shock bushings!!!
Old Jan 12, 2013 | 03:46 PM
User 020415
I like those tips! Thanks guys.
Old Jan 12, 2013 | 04:33 PM
renegad44's Avatar
renegad44
Where else, Harbor Freight......
If you can't find it at yours, let me know, and I'll send you some from mine. Shouldn't take but a day or two to get to you.
Old Jan 12, 2013 | 04:46 PM
dmarkshark's Avatar
dmarkshark
Lol, Ok, never thought of looking there, they certainly have lots of items, but not a lot of that kind of stuff. I'll check it out.
Old Jan 13, 2013 | 10:32 PM
renegad44's Avatar
renegad44
I'm not having a problem with the sqeaking noise now, and I know they say, "if it ain't broke, don't fix it," but my shocks have been on for probably 50k miles now, so, since it's raining so damn much here, tomorrow too, I think I'll do what you suggested to the lower shock bushings tomorrow . That will give me something to do!!
Old Jan 14, 2013 | 02:46 PM
User 020415
I just told it's my tie rods.
Old Jan 15, 2013 | 03:09 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
__________________
..................Click for
To squeaking noise
