LG Short Shifter Installed
Old Jan 16, 2013 | 10:14 AM
V2lude's Avatar
V2lude
Default LG Short Shifter Installed
Hello all, I don't post here too often but I wanted to share my experience with the LG short shifter. It seems to be a relatively uncommon choice for some reason and I have no idea why. Maybe it's because it's one of the least expensive. Why did I buy it? I chose this shifter because its the best deal. It comes with a new **** as well, all for around $200. Below are some install pics, I tried to make it look as OEM as I could. If anyone has any questions about the shifter, I will be glad to answer.
The stock shifter.
I cut the hard plastic off the bottom of this rubber insulator to help fit and finish.
Notice how the boot will not fit around the new ****. My solution is below.
The final product.
Old Jan 16, 2013 | 10:24 AM
maxx2200's Avatar
maxx2200
Nice work and pics. I like the ****. Thanks for posting.
Old Jan 16, 2013 | 11:56 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
That's a great shifter. Looks good too
Old Jan 16, 2013 | 11:58 AM
That shifter looks really good. How is the shift action compared to the stock one?
Old Jan 16, 2013 | 12:40 PM
V2lude's Avatar
V2lude
The shifts are significantly shorter than stock. It took me a while to get used to how short it was. It has centering springs to help with the 2-3 shift. Because of the springs and the new motion ratio it is way harder to move the shifter laterally. I've gotten used to this, but some might not like it. You can easily change out the springs. The shifts are real precise and I can shift the car a good bit faster. However, it can be noisy at times, especially Under hard acceleration. I assume it is the centering springs. I'm very happy with it! I really dont know why more prople dont have it. And thanks for the compliments!
Old Nov 12, 2023 | 08:26 PM
corvttdude's Avatar
corvttdude
Attachment 48377651
Attachment 48377652
The stock shifter.
Attachment 48377653
Attachment 48377654
Attachment 48377655
Attachment 48377656
Attachment 48377657
Attachment 48377658
Attachment 48377659
Attachment 48377660
The final product.
when I went to install mine, the length of the shaft below the mounting plate is too long, and contacts the lower box when trying to put it into first, did you have this problem?
To LG Short Shifter Installed
