I agree that as long as the offset is correct, those wheels will fit fine on your car - they are basically the same widths as the Z06 has on it. You can check with a resource like the Tire Rack on the compatibility of the tires with the wheel widths - 8VETTE7 is right on the front tires and you should also check the rears to ensure that their width will be OK on a 10.5 inch wide rim.
