Help replacing front turn signal light
Old Jan 27, 2013 | 11:53 AM
luckstr's Avatar
luckstr
Default Help replacing front turn signal light
What is the best way to replace my passenger side front turn signal bulb on my 2004 C5 ? It has blown out and the turn signal is very rapid due to this. Do I have to remove the nose mask ? It was a struggle getting it on. Thanks
Old Jan 27, 2013 | 11:56 AM
Clint43's Avatar
Clint43
Go to youtube and look up junkman he has a video on how to replace them, very easy just type in junkman replacing DRL's
Old Jan 27, 2013 | 12:00 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Jack the front end up about 12"-18" and remove the plastic cover in the front corner and you can get your hand in there!
Or take out the headlight assembly and reach down to get at it!
Old Jan 27, 2013 | 12:03 PM
luckstr's Avatar
luckstr
Thanks.
Old Jan 27, 2013 | 04:07 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
You may have a hole burned in the top of the housing; caused by the heat of the bulb. this hole, allows moisture from rain, or car wash into the housing, burning out the bulb.
this happens on many many C5's.
You most likely need to replace the housing, which is not difficult, or your new bulb will just get wet too, and burn out again and again.
There are other posts here, showing how to do this. Just need to get new housing, raise the front of the car a little, so you can get at it.
Old Jan 27, 2013 | 04:33 PM
65GGvert's Avatar
65GGvert
This is the fastest way:
http://www.google.com/url?sa=t&rct=j...41524429,d.eWU
Old Jan 27, 2013 | 05:21 PM
James2002z06's Avatar
James2002z06
BK as I've said before you would be a blast to hang out with .....
That was classic...
Old Jan 27, 2013 | 05:35 PM
FLZapped's Avatar
FLZapped
Originally Posted by 65GGvert
I use this technique. Going through the brake duct opening works great, especially since my arm is too big to get in any other way.
Old Jan 27, 2013 | 05:37 PM
This is the access panel under the front fascia. Held in by a few screws.
Old Jan 27, 2013 | 06:14 PM
jrose7004's Avatar
jrose7004
I use the bottom access panel.
Old Jan 27, 2013 | 06:22 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Turn on your headlights, take off the bezel and reach down to get the bulb, takes 5 minutes
Old Jan 28, 2013 | 12:44 AM
PhysicsDude55's Avatar
PhysicsDude55
I used the "in through the brake duct" method, and it worked, but one one side I chipped the paint in the process . My hand caught a flake of paint and the clearcoat came off about the size of a dime. Doesn't look that bad, but I can always notice it, and my hands are not that big. I wear a medium size glove and it was a tight squeeze.
To Help replacing front turn signal light
