Winter project: reduce console heat
Old Jan 28, 2013 | 05:40 PM
RockJustBelow's Avatar
RockJustBelow
Default Winter project: reduce console heat
One of my winter projects was to address the console heat issue that I noticed over the summer. I didn't really notice the problem with short 15 - 20 min. trips. However, I took a 1+ hour trip and notice the console heating up considerably. So, I did plenty of searching for a solution on the forum and google for ways to control the heat in the cabin.
NOTE: my car has 1 7/8" headers, x-pipe & hi-flow cats.
First, I decided to do the "Frost King mod" just on the top of tunnel inside of the car.
Next, and more importantly, I wanted to address controlling the heat underneath the car. I considered buying an Elite Engineering 1/4" Thick Aluminum Ceramic Coated Tunnel Plate with Thermal-Abs however, I didn't want to spend $300 on a tunnel plate. So, I did some more searching and found a forum thread of a C5 turbo vette build that persuaded me to do the following.
1. I bought a 2011 C6 Grand Sport aluminum tunnel plate from a forum member for $50. The C6 plate is 1/8" thick, which is twice as thick as a stock C5 sheet metal plate. It's pretty sturdy compared to the C5 plate. My car is a Z06, if it was a coupe or vert then I'd consider a 1/4" plate.
2. I then bought a 21" x 48" piece of DEI Floor & Tunnel Shield II Heat and Sound Insulation (about $80). This 3/16" shield can handle up to 1750 degrees and the adhesive can handle up to 450 degrees. I cut the shield to fit the plate and drilled holes for the tunnel bolt washers to fit against the aluminum for a positive hold.
3. Removed the backing and applied the shield to the tunnel plate then installed the plate. I ended up replacing the tunnel bolts (because one had broke) with M6-1.0 x 22.5mm Hex Head zinc plated bolts that I got online (http://www.clipsandfasteners.com/M6_...c_p/a15778.htm). A box of 50 bolts was $9.12 + shipping. The Chevy dealer wanted $1.32 per bolt!
4. Next, I took some of the excess shielding and cut out pieces to insulate the sides of the tunnel below the plate.
C6 plate with the DEI shielding cut out.
Plate and shielding installed.
Exhaust back on.
So, the entire project ran me about 1/2 the cost of the Elite plate and I like to think that the additional insulation will keep things cooler. Right now it's 30 degrees outside so I'll have to wait a little while for things to warm up around my area to see first hand how well this works.
Old Jan 28, 2013 | 05:43 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Great job and creative solution! I went with the RaamAudio Ensolite and BXT II heat/sound material and dropped the cash for the Elite Engineering tunnel plate with Thermal Abs. A definite, but more costly, improvement.
Old Jan 28, 2013 | 05:49 PM
maxx2200's Avatar
maxx2200
Great info and pics. I appreciate your taking the time to post this up. Posts like this is why this forum is so great.
Old Jan 28, 2013 | 06:35 PM
RockJustBelow
Thanks!
My car has some sound deadening material in it already so I only focused on the console heat. I was getting some sound around the shifter but I fixed that with a better fitting isolation plate and Frost King insulation.
It looks like you have a vert. I'm sure the 1/4" plate helped in stiffness and heat.
Thanks...it's the least I can do to give back to the forum.
Old Jan 28, 2013 | 08:30 PM
MSG C5's Avatar
MSG C5
Originally Posted by RockJustBelow
Thanks!
It really has. I also installed new Koni FSD shocks and Z06 sway bars with the tunnel plate. I can really feel the extra tightness of the chassis. The car corners like it's on rails!
Old Jan 28, 2013 | 09:56 PM
Looks like you came up with a great solution and saved a bunch of money in the process. Congrats.
Old Jan 28, 2013 | 10:10 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I love a creative mind at work! Very nice job and professional looking!
Please post up your over thoughts on how this works, do the Snickers bar test to see if it doesn't melt!
Old Jan 29, 2013 | 06:17 AM
WKMCD's Avatar
WKMCD
Insulating the tunnel plate will make a big difference.
Old Jan 29, 2013 | 07:21 AM
RockJustBelow
Thanks all! I'll update the thread after I do a long test run.
Old Jan 29, 2013 | 11:13 AM
LoneStarFRC's Avatar
LoneStarFRC
Time for a road trip to Texas in mid-August to test out your work.
Really would be nice to see how the adhesive holds up over time.
Nice work.
Old Jan 29, 2013 | 11:36 AM
RockJustBelow
Nice work.
Thanks! Yes, I'm real curious about how well the adhesive holds up over time.
Old Feb 24, 2022 | 01:17 PM
Justin Raney's Avatar
Justin Raney
Is this poster still around? I was looking to do the same as you direct fit the c6 plate on a 99 c5.
Old Feb 25, 2022 | 12:31 PM
helga203's Avatar
helga203
OP gone.
Old Feb 25, 2022 | 02:42 PM
Justin Raney
Originally Posted by helga203
OP gone.
He has the correct bolts listed for the tunnel plate shield? I have the tunnel plate but dont have the correct bolts.
To Winter project: reduce console heat
