Popup headlamp
Old Feb 5, 2013 | 09:32 AM
eylesda's Avatar
eylesda
Default Popup headlamp
Anyone know how to stop my headlamps popping up fully when I have just the side lights turned on?
They pop up but do not light up.
When I turn the lights on fully they then light up.
Did not used to happen!
Old Feb 5, 2013 | 10:23 AM
3boystoys's Avatar
3boystoys
Stalk is probably broken.
Old Feb 5, 2013 | 11:04 AM
VetteCrazyRichard's Avatar
VetteCrazyRichard
I need to replace my stalk too. $169 new on ebay. Free shipping. Installation or repair is available here in forum also. Repair seems a little above my pay grade.
Old Feb 6, 2013 | 05:55 AM
o2bnkc's Avatar
o2bnkc
Believe it or not, that is also could be a bad headlight gear. Does your headlight motor keep running a few seconds after you turn the lights off?
Old Feb 9, 2013 | 07:10 AM
eylesda's Avatar
eylesda
Yes, i hear a loud whirring noise for about 5 seconds after the lights go down........
Old Feb 9, 2013 | 07:32 AM
swpowell's Avatar
swpowell
It is easy to correct the problem and fix the gear yourself.
Check out this video on YouTube:
I will go find the kit info and post here for you
Edit: here is the gear rebuild kit I bought: http://www.rodneydickman.com/corvette.html
I fixed mine 3-4 years ago and still work like new.
Hint: go ahead and put new bulbs in while it is easy and all apart.
Old Feb 9, 2013 | 06:37 PM
o2bnkc's Avatar
o2bnkc
Yep, it's the gear.
To Popup headlamp
