Looking for temporary cheap alternative to my ripped stockers. (I know they're terrible seats) Just looking to find if they will fit. It says they are 21 inches wide. I can do fab work to adapt them to stock brackets, thats not an issue.
My guess is they won't fit well. unless you are short, they won't slide back far enough. The gas tank is right behind the seats. The "hole" or "area" or "pocket" for a C5 seat is relatively small and C5 seats are designed for that "hole". Take one of your seats out and see what I mean. Unless the seller offers a money back guarantee that they will fit a C5, I recommend that you don't buy them.
That **** sticks out way too far on the side. You would have to cut out the interior trim piece directly behind the seat so it could be adjusted. I had to cut mine and my Sparco's don't even have such a large **** like your ebay picture.
Thanks!
I don't know about the seat covers but I welcome to you and ManOfWar to the Corvette Forum.
They look like pretty nice seats. They will most likely fit if you convert over to C6 seatbelts as it will remove the large seatbelt roll from the bottom. You can check out my thread where I installed viper seats to give you an idea.http://forums.corvetteforum.com/c5-g...erior-ect.html
