changing gauge cluster faces
Old Feb 6, 2013 | 04:20 PM
rbrumm's Avatar
rbrumm
Default changing gauge cluster faces
I cant't remember if I have asked this question before, (getting old )
I am thinking about changing out my gauge cluster faces to the white ones.
My queston is..... Is it a big pain in the butt to do or is it fairly easy I'm plan on getting them from corvette central
thanks for your input
Old Feb 6, 2013 | 06:46 PM
Read this, or just do a search using Gauge cluster faces.
http://forums.corvetteforum.com/c5-g...+cluster+faces
Old Feb 6, 2013 | 07:09 PM
CQRT's Avatar
CQRT
Originally Posted by rbrumm
my queston is..... Is it a big pain in the butt to do i'm plan on getting them from corvette central
yes !
Old Feb 6, 2013 | 10:10 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Takes a while, if you don't have HUD that would be the time to do it, although you can remove the cluster without removing the dash pad, it's kinda tight removing the wiring from the back of the cluster but it can be done, just make sure you drop the column as far down as you can get it and cover everything on the top of it so you don't scratch everything up, and take your time.
Old Feb 6, 2013 | 11:15 PM
rbrumm's Avatar
rbrumm
Thanks for all the replys. The more I read The more i think the black ones are just fine
Old Feb 7, 2013 | 02:52 AM
corvettedaddy11's Avatar
corvettedaddy11
I changed mine to white face pretty easy..!
To changing gauge cluster faces
