Driver Window grating sound when lowered
Old Feb 9, 2013 | 09:04 AM
Burgie's Avatar
Burgie
Default Driver Window grating sound when lowered
My 03 Vert's driver's window makes a horrible grating/grinding sound when lowered. If I push against the inside of the window out while lowering, the sound stops. Before I open up the door panel, does anyone know what it may be or had a similar situation. Thanks
Old Feb 9, 2013 | 09:37 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I had an issue like that a few years ago and in my case it was a small cable that was frayed a bit, I replaced the regulator with a GM unit and has worked fine, I first tried a rebuilt unit and it worked, But was really slow going up and down.
Mr.Bill
Old Feb 9, 2013 | 12:34 PM
Burgie's Avatar
Burgie
Mr.Bill
Is it much of a job to pull the panel and repair? What kind of cost is the unit you were speaking about from GM
Old Feb 9, 2013 | 12:36 PM
Mr.Bill's Avatar
Mr.Bill
It is really easy, Just pay attention when removing the regulator, As far as cost I believe it was around 100-125.
Old Feb 9, 2013 | 12:55 PM
C5 4me's Avatar
C5 4me
I hope I did this right.Here is a youtube vid on how to replace it.I did it and its not hard at all.
Old Feb 9, 2013 | 04:48 PM
To pull the door panel, look on www.vetteessentials.com and go to the installation instructions for the door pulls. It will show you how to get the door panel off. It is actually very easy.
Old Feb 10, 2013 | 08:52 AM
Burgie's Avatar
Burgie
Default Thanks
Thanks everyone, looks like a project for today and possibly order replacement tomorrow.
Old Feb 10, 2013 | 10:22 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Mr.Bill
I was wondering about that. I had to replace my driver's side regulator and it goes significantly slower than the passenger side factory unit (pretty sure the replacement was aftermarket) Is the motor in the aftermarket units weaker?
Old Feb 10, 2013 | 07:17 PM
SFL_driver's Avatar
SFL_driver
Definitely your window regulator. Mine was making the same sound for a week or so, then it stopped going down all the way. Installed a new one and problem solved. I bought a GM unit from Amazon.
One trick... Before you remove the glass mark its position with a few pieces of blue painters tape running vertical from window onto door. Then cut a seam with a knife so you can remove the glass.
Old Feb 11, 2013 | 07:56 AM
Burgie's Avatar
Burgie
Thanks again for all your help. I'll go on the GM Parts site and order a new assembly.
Old Feb 11, 2013 | 10:19 AM
Burgie's Avatar
Burgie
When looking at the GM site for window regulators they quote a price but my concern is-Is this for the entire assembly or just some electronic box? They want 176.00 bucks for it? Anyone know as I can't seem to get a response from the GM Parts site.
Old Feb 11, 2013 | 10:23 AM
Big Duk's Avatar
Big Duk
It will be the whole assembly
Mr.Bill's Avatar
Mr.Bill
When you buy a regulator you also get the motor and the whole 9 yards.
Old Feb 11, 2013 | 10:25 AM
Burgie's Avatar
Burgie
Thanks, thats what I wanted to know.
Old Feb 11, 2013 | 10:27 AM
Mr.Bill's Avatar
Mr.Bill
It would be my guess that an after market unit has a weaker motor.
Old Feb 11, 2013 | 02:47 PM
baxsom's Avatar
baxsom
might want to order a few of the plastic clips that hold the door panel to the door too. they tend to break if you pull just right.
Old Feb 12, 2013 | 08:52 AM
Burgie's Avatar
Burgie
Thanks-I did it slowly and they appear intact and undamaged.
To Driver Window grating sound when lowered
