Throttle Body Removal
Old Feb 10, 2013 | 02:43 PM
stevegray04's Avatar
stevegray04
St. Jude Donor '14
Default Throttle Body Removal
I posted this in the "Tech" section, but I'll do it here too. I'm sure that TB removal and cleaning has been covered many times, but I'm new to C5 ownership. I've read that the TB is easily located by first removing the air cleaner assembly, then two or three bolts. I have not found any YouTube videos for this procedure and Haynes appears not to have made a DIY book for the C5. Thank you for any guidance you can give me.
Old Feb 10, 2013 | 03:41 PM
Sonny71's Avatar
Sonny71
Oldtimer
Take off the electric harness, coolant bleed hose and clamp, then the throttle body bolts. That's it, be sure to use a new gasket.
Old Feb 10, 2013 | 03:44 PM
c31980's Avatar
c31980
remove the air bridge .and one hose on the left 2 elec connector shuld be discon. 3 10mm bolts one at the top on the tb 2 down in each corner be curfull not to drop the lower one easy to lost . .. clean the tb with carb cleaner or what ever ..
To Throttle Body Removal
