Hood Alignement
Old Feb 10, 2013 | 05:45 PM
silver408z's Avatar
silver408z
Default Hood Alignement
Not sure how it happened but one day I just noticed that the front lip of my hood was sticking up above the nose. How do I fix this? Picture showing what I am talking about.
Old Feb 10, 2013 | 06:21 PM
onlyavette's Avatar
onlyavette
Its not the hood. Its droopy nose syndrome. Loosen all the fastening screws under the nose and take out the push pins that are under the front edge of the hood that hold the facia (nose) to the frame. Push the nose up from the bottom center and tighten all of the screws. I used nylon 1/2-20 nylon bolts and washers and plastic washers for shims between the nose and the frame to shim it up flush with the hood. I was able to make it flush all the way across.
I was surprised how far the nose would move up and down when all of the screws were loose.
It takes time and patience but the head light covers can be adjust to fit better too.
Old Feb 10, 2013 | 07:02 PM
silver408z's Avatar
silver408z
Thanks for the responses and I will do the recommendations.
Old Feb 10, 2013 | 10:01 PM
Thanks for the info - saved this for future reference.
To Hood Alignement
