Clutch Fluid
Old Feb 11, 2013 | 06:28 PM
injun.724's Avatar
injun.724
Default Clutch Fluid
What type of fluid does the clutch master cylinder take on a 1999 six speed?
Old Feb 11, 2013 | 06:35 PM
dbaker's Avatar
dbaker
A good Dot4 brake fluid should be fine.
Ranger has a good clutch care vid & read.
http://www.rangeracceleration.com/Clutch_Care.html
\db2
carolina
Old Feb 11, 2013 | 07:00 PM
sfc rick's Avatar
sfc rick
DOT 3 !!!! per owners manual!!!
Wow just noticed that Dot 4 may be used if it's compatable.....but you have to be sure by reading each brand's bottle.
Still with Dot 3 your safe per owners manual.
Old Feb 11, 2013 | 07:52 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
I used Delco Supreme 11 DOT-3 last time I ranger'd it. Tried to buy the same stuff from the dealer last month and it has been superceded by a DOT-3 'Brake & Clutch Fluid', not to be confused with the Delco Super DOT-4 Clutch and Brake Fluid which has been available for a while and is used in the Ranger video.
The first time I ranger'd the clutch, I used the Super DOT-4 fluid and the clutch squeaked when it was depressed. Immediately changed it out for DOT3 and the squeak went away. My .02.
Old Feb 11, 2013 | 08:22 PM
When I had my 6-speed '00 coupe and changed the clutch fluid, that's what I used.
Old Feb 11, 2013 | 09:20 PM
71corv's Avatar
71corv
St. Jude Donor '08
I use Prestone DOT 4 and have no problems.
Gene
Old Feb 11, 2013 | 09:32 PM
rws.1's Avatar
rws.1
Valvoline DOT3& DOT4 is what I use for daily use.
Old Feb 11, 2013 | 09:51 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Prestone Dot 4 here as well.
Old Feb 12, 2013 | 04:33 AM
baxsom's Avatar
baxsom
Didn't the manual get updated to change the fluid from DOT 3 to DOT 4? Same as the manual was changed altering the plug gap?
Old Feb 12, 2013 | 06:44 AM
FLZapped's Avatar
FLZapped
DOT 4 is fine, it is DOT 5 that is not backward compatible.
Old Feb 12, 2013 | 09:01 AM
injun.724's Avatar
injun.724
Default Confused
So which is it, Dot 3 or 4 that is the best to use ?
Old Feb 12, 2013 | 01:32 PM
3boystoys's Avatar
3boystoys
It says right on the CAP!
Old Feb 12, 2013 | 02:17 PM
baxsom's Avatar
baxsom
the caps were put on when DOT 3 was the recommended fill. Now GM has changed the recommendation and says to go with DOT4. You can mix 3 and 4 no problem just remember if you mix 3 and 4, you just have a full fill of DOT3 afterwards. The difference is a higher boiling point of DOT 4. GM also updated the plug specs and oil specs as well so what was written when the car was new is no longer 100% valid.
To Clutch Fluid
