Bonehead move, wtf!
Old Feb 14, 2013 | 09:30 PM
Tommyxgun's Avatar
Tommyxgun
Default Electrical tape removed clearcoat! Ahh
Had A piece of electrical tape on the back bumper behind the wheel to keep the salt from beating up the paint. Peeled it off tonight and it pulled clearcoat with it! Suggestions? Spray it with clear or go over it with touch up spray paint? Effin idiot move!
Old Feb 14, 2013 | 10:04 PM
SSTG's Avatar
SSTG
Electrical tape should not have removed your clear. If it did, you might be experiencing clear coat failure.
Pics?
Old Feb 14, 2013 | 10:12 PM
bumble-z's Avatar
bumble-z
Pics?
I agree.
Wonder if perhaps that area/panel could have been repainted at one time or another.
EDIT>>> You sure that's not the gummy residue from the electrical tape?
Old Feb 14, 2013 | 10:14 PM
Tommyxgun's Avatar
Tommyxgun
Old Feb 14, 2013 | 10:17 PM
C5FORFUN2's Avatar
C5FORFUN2
Yep, looks like someone did a quicky repaint. Probably to cover up chips like you were trying to prevent.
Old Feb 14, 2013 | 10:22 PM
Tommyxgun's Avatar
Tommyxgun
Could I wet sand and respray clear? Area isnt noticeable but will bugg me
Old Feb 14, 2013 | 10:38 PM
robert miller's Avatar
robert miller
Only if you know what you or doing here.
Old Feb 14, 2013 | 10:48 PM
Tommyxgun's Avatar
Tommyxgun
How bout some touchup paint then? Lol. Plastidip? Haha
Old Feb 14, 2013 | 11:08 PM
duramaxsky's Avatar
duramaxsky
PM sent
Old Feb 14, 2013 | 11:16 PM
Tommyxgun's Avatar
Tommyxgun
http://www.amazon.com/gp/aw/d/B0013OWOBA hide it with these?
Old Feb 15, 2013 | 12:09 AM
Check with a trusted body shop and see if they can sand and respray the clear. Hopefully that would fix the area.
Old Feb 15, 2013 | 07:41 AM
SSTG's Avatar
SSTG
What about high quality Black Vinyl like 3M 1080.
People clear bra that area and it would look similar. And it would save rock chips later.
Old Feb 15, 2013 | 07:50 AM
rkhegler's Avatar
rkhegler
Personally, I would take it to a body shop, especially if the the rest of the body paint is in good shape. They can do the proper repair. Check with your insurance company for your deductibles.
Old Feb 15, 2013 | 10:23 AM
3boystoys's Avatar
3boystoys
Time for mud flaps.
Old Feb 15, 2013 | 10:50 AM
HT1663WB's Avatar
HT1663WB
I would get a set of C6 Splash Guards. They fit nice with a little dremel work. They are low profile and cost about $100.00 from GM. They come in a set of 4. I used them on all 4 corners. Here they are on my Z06
You could also pick up a can of Dupli Color spray, in the color of your Vette, and shadow that area. Sand down the damaged spot, just inside the wheel well, tape of the edge really good and spray the damaged area. Once done just wet sand the edge, hit it with a buffer and it will look fine. It wont be as shiny as the out side of the bumper cover but it will give the illusion of a shadow caused by the tire.
Good Luck!
Old Feb 15, 2013 | 10:55 AM
HT1663WB's Avatar
HT1663WB
No Not those..these. 19170234 – 2005-2009 Splash Guards.
Old Feb 15, 2013 | 11:08 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
First I ever heard of someone using tape in this manner. You can sand, repaint and then clear coat it, or take it to a body shop. Shouldn't cost much to fix that.
To Bonehead move, wtf!
Old Feb 15, 2013 | 12:18 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Sorry for your problem. I remember using painters tape when autocrossing & not having any problems removing tape. Good luck with your fix...
Old Feb 15, 2013 | 03:50 PM
Tommyxgun's Avatar
Tommyxgun
I used to do this on my old black focus. Body kit took a beating during winter. Nobody can tell its even taped. I didn't ever think this would happen. I might just sand it lightly and hit it with some paint. A- it can't be any worse then it is. B- it'll keep it from peeling more. C- looks bad I can take it to a shop or buy the splash guards.
Old Feb 15, 2013 | 04:05 PM
MoEngineer's Avatar
MoEngineer
I tired to touch-up the clear on mine. It can't be done with a can. It takes a shop that can blend the clear with reducer, and even then they normaly take it all the way back to a body line. That is what I finally had to do. Don't kid youself into thinking you can wetsand and make it blend either.
