A Grounding Solution
Old Feb 17, 2013 | 08:32 PM
thmehr's Avatar
thmehr
Default A Grounding Solution
I read the issues on this forum about ground problems with the C5 wiring. The other day, I was in the part stores and I saw a can of spray used on the battery terminals to prevent corrosion. Has anyone tried this on the ground point connections?
Old Feb 18, 2013 | 08:37 AM
sunchaser73's Avatar
sunchaser73
When I cleaned my ground connections a couple of years ago, I sprayed the frame stud/nut with some battery terminal protectant. Seems to have held up just fine.
Old Feb 18, 2013 | 12:00 PM
dadaroo's Avatar
dadaroo
Battery cleaners like you describe are fine to use on the ground connections to clean the area if you have corrosion. They are intended to help neutralize acid and remove corrosion deposits. Just clean the area afterwards to remove the cleaner.
Old Feb 18, 2013 | 12:31 PM
SSTG's Avatar
SSTG
Do you ir anyone else have a diagram showing the locations of all the Grounding points?
Old Feb 18, 2013 | 07:07 PM
Zorlac's Avatar
Zorlac
https://www.corvetteforum.com/c5-tec...tion-long.html
Hope the link works. Was using my phone.
Old Feb 18, 2013 | 07:52 PM
thmehr's Avatar
thmehr
I guess I have another project to work. Thanks for your insight
Old Feb 18, 2013 | 09:02 PM
RMB97LS1's Avatar
RMB97LS1
^^that is a GREAT thread and a must do in my opinion!
Old Feb 18, 2013 | 09:27 PM
SSTG's Avatar
SSTG
Thank you!
Old Feb 18, 2013 | 09:36 PM
jeffsmachine's Avatar
jeffsmachine
Originally Posted by SSTG
Thank you!
Ditto
To A Grounding Solution
