Brake duct screen install
Old Feb 22, 2013 | 10:08 AM
David Shiel's Avatar
David Shiel
Default Brake duct screen install
went a bit wrong. Anyone had experience with them? One went in just fine and looks great. The other was so tight that an end wire in the weave came out while I was attempting to pull it into position. I have since determined that one was cut larger than the other.
I taped off the ducts to prevent any paint damage and proceded carefully, as they have no edging, but still encountered the fit issue. Anyone have any hints on this? I am thinking of making a cardboard template before I try the new one they are sending.
I want to add that Corvette Mods was outstanding in their response and service, and notified me the same day I called them that a replacement screen was on the way. I have always had great experiences with them and with their products.
The front fog light Z06 screens and the rear ones fit perfectly.
Old Feb 22, 2013 | 10:34 AM
chassed's Avatar
chassed
Those front break screens are a PITA!!
Old Feb 22, 2013 | 10:49 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Where are you installing the screens? Some installations have them pressure fitted between the brake duct and the front fascia but I installed my RaceMesh front brake screens into the the first groove inside the brake duct per the instructions on their website.
I taped off the edges of the fascia just to be safe and then after placing it inside the brake duct, I pulled it back into position with a pre-installed zip tie and needle nose pliers. I then cut off the zip tie once it was in place.
Old Feb 22, 2013 | 11:05 AM
Mark Maple's Avatar
Mark Maple
I found using a couple of zip ties to really help the installation of the screens. I can't remember if I even zipped them closed or just threaded them through the screen allowing you to pull the screen toward you once it is in the brake duct.
Old Feb 22, 2013 | 11:09 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Mine are sandwiched in between the vent and the tube.
Old Feb 22, 2013 | 11:11 AM
MG RED 99's Avatar
MG RED 99
How are you trying to install them? If you go from under the car and remove the closeout panel you can pull the duct back and easily set the screen in it and then let the duct push back against the painted fascia. Trying to install them trough the painted opening is risky since you can easily scratch the paint even with it masked off, and you are also trying to fit the larger diameter screen through the smaller opening. This also keeps the screens close to the front for a clean look. Just another suggestion if you still have trouble. Good luck.
I got my screens from West Coast Corvette, fyi.
[IMG][/IMG]
[IMG][/IMG]
Old Feb 22, 2013 | 12:46 PM
David Shiel
Default Ok, some seem to have them in the first groove
and others seem to have been able to get them right up against the front fascia opening. (How did you do that?) Racemesh shows them in the first groove at least 1/4 inch back from the fascia edge. I don't mean to appear denser than I am, but would prefer them up against the fascia.
Also the instructions I got say, after inserting through the opening after taping[B],"simply pull the screen forward to between the duct and front fascia"[/B] This implies that they do not sit in the first groove. Further, my instructions did not say to remove the inner fender liner, but rather tape and insert through the opening. To me removing the liner is the way to go and what I intend to do.
Racemesh says they are marked left and right ...............mine were not, but not hard to figure out.
As an aside, Mine were shipped to me from Ken Pettit, Vetteshop, LLC in Port Orange,FL. So, may not be Race Mesh.
I really appreciate the input, as I want the best looking result.
Old Feb 22, 2013 | 12:55 PM
MG RED 99's Avatar
MG RED 99
I don't recall what the instructions might have said for mine when I did the installation but, if you can raise the front of the car you will see a plastic cover panel directly underneath the area of the brake duct. It's kind of pie shaped and about 12" across, forgive me I'm just going on memory but I'm sure someone can post a pick of the underneath front portion of the car. this panel is held on with a few hexhead screws. You do not need to pull the wheel well fender liners. These panels are there for the specific reason to gain access to the turn siganl lights and fog lights. Once this cover is off you can see the brake duct. The duct is simply held in place against the fascia with pressure from the corrugated ribs it has. Simply pull it back a bit and place the screen in there and allow it to press back against the fascia. This should provide you with the screen right up against the painted fascia. I'll try to find a picture of the panel that needs to be removed.
You can check this link for the panel details:
http://forums.corvetteforum.com/c5-g...b-2000-c5.html
Old Feb 22, 2013 | 01:09 PM
MSG C5's Avatar
MSG C5
I guess it would depend on the actual size of the screen, although regardless of the manufacturer, they should all be pretty close to the same size. I had originally bought a set of wire brake duct screens from WCC a few years ago. They looked like regular mesh and the instructions were to pressure fit them between the plastic brake ducts and the front fascia.
I followed the same instructions you outlined above. What worked for me was to move the brake duct as much as possible leaving me the room to work the screen into place against the backside of the front fascia. Once the screens were where I wanted them, I simply moved them over a little and then repositioned the brake duct. Once in place, you can then adjust the screen by pressing on it to make sure it's centered. As mentioned, make sure you apply some layers of painters tape around the inside of the fascia openings to make sure the sharp edges of the screens don't scratch. I never had a problem with it because you insert the screens sideways and then adjust them after they are inside the fascia.
I never liked the idea that the screens were only held on by the pressure of the brake duct, so when I replaced the original screens with the RaceMesh, I followed their directions and installed them into the 1st groove of the brake duct. I like the look of them sitting back a little further, plus I know they are locked in pretty tight. Below is a link to the Racemesh instructions (for reference). What's weird is that their pictures showing them installed are different than those they use for installation.
Another tip is that I drove up on ramps to get the front end up a little higher. It was much easier to perform the work that way vs. crouching down on the floor.
http://www.racemeshgrilles.com/installation.htm#C5
Old Feb 22, 2013 | 01:27 PM
David Shiel
Default Great input
Now I know how I will proceed. Makes sense.
Old Feb 22, 2013 | 01:29 PM
David Shiel
Default Thanks to all I now have all the input
I will need to get the result. I will remove the panels and rock ! You guys are great. Thanks to all
Old Feb 22, 2013 | 01:31 PM
rocknroller's Avatar
rocknroller
Interesting. What is the function of these screens?
Old Feb 22, 2013 | 01:50 PM
MSG C5's Avatar
MSG C5
No real function. Style points only as I'm just trying to get to my 37 pieces of flair...
Old Feb 22, 2013 | 02:52 PM
David Shiel
Default Well for us
hopeless narcissists with huge ego deficits, some of whom drive convertibles for added gratification, it is just a little bit more of "look at me" stuff to make us feel better. And, in addition, for us retired guys it gives us something to live for and....... well it might keep vampire bats from being sucked in and triggering our ABS on a hot summer night. It is also an economic stimulant which keeps the USPS people employed delivering stuff we don't need and may not like once installed, but can't stop buying.
Old Feb 22, 2013 | 03:08 PM
MG RED 99's Avatar
MG RED 99
You can see in this thread how to remove the closeout panel
Old Feb 22, 2013 | 05:10 PM
David Shiel
Default Thanks,
I am going to do it that way.
Old Feb 22, 2013 | 09:27 PM
When I installed my front brake duct screens, I put them in going through the opening in the front - taped the fascia area to prevent any scratching of the paint. It was a PITA to get them in just right and then get them to sit in the brake duct. If I ever have to do it again, I will use the above procedure to get them installed.
To Brake duct screen install
Old Feb 25, 2013 | 03:29 PM
David Shiel
Default This is definitly the procedure I will follow.
For anyone with the screens supplied to CorvetteMods by the Vette Shop in Fl, Ken Petitt, You should definitely follow this and not the instructions provided. I have suggested that those instructions be changed to reflect installation via removal of the light access panel. It might take a bit longer , but is the only safe way to get the screens tight up against the fascia.
Old Feb 25, 2013 | 04:23 PM
swpowell's Avatar
swpowell
Thank you!
Old Feb 25, 2013 | 05:41 PM
MG RED 99's Avatar
MG RED 99
Originally Posted by swpowell
Thank you!
My pleasure. Just trying to give back to the community.
