Apparently, like other GM models, C5's don't have long lasting "regulators", as my passenger window will not go up! (Can hear the linkage clanging around) although motor is working. Any estimates on a fair price for regulator, and/or labor to replace?? Also, a local body shop guy I know said something about "re-programming" window?? Why in the hell would that be necessary if all I'm doing is replacing the guts (regulator) that holds the window??? Help!
I just replaced mine on the driver's side. Ordered a GM part as the knock offs were cheaper but slower in raising or lowering the window. I used http://gm-partscenter.com/ as the source ($202.00) shipped and I'm sure you may find cheaper out there. Took about fifthteen minutes to install once the panel was off.
