Passenger Window Doesnt always work
Old Feb 25, 2013 | 05:30 PM
BryanV's Avatar
BryanV
Default Passenger Window Doesnt always work
So my passenger window works when it wants to. If I use it everyday it will work but my car sits for the weekend it wont.
Ive tried slamming the door, hitting the door panel etc and nothing. I can push the window down button and watch the lights flicker on the radio/climate controls.
Any help?
Old Feb 25, 2013 | 06:00 PM
jcgunn's Avatar
jcgunn
Sounds like the regulator. It's a POS part. Here is a how-to with some pictures. The part is not Vette specific, and GM uses the same low quality piece on some of their low end cars...
http://forums.corvetteforum.com/c5-g...o-replace.html
Old Feb 25, 2013 | 06:03 PM
Robert1Stock's Avatar
Robert1Stock
Hi Bryan,
I had the same issue on my 03 z06, the dealer thought it was the regulator, replaced it and no dice. They replaced the motor and I told them take the other part out because I wasn't paying for something that wasn't the problem, they did... and it again didn't work. So in the end they had to replace both but I was lucky enough they only charged me the 1 part.
That or nothing was broken and they dooped me......
Old Feb 25, 2013 | 10:38 PM
BryanV's Avatar
BryanV
Thanks guys...link doesnt work for me?
Robert- So new motor fixed it?
Old Feb 25, 2013 | 11:57 PM
jcgunn's Avatar
jcgunn
sorry the link is broke, just search the forum for "window regulator replacement"...the forum search engine is WAY stupid, but will eventually get there. The part is $60-90 online with a motor included, just replace the whole thing. The hardest part (at least for a Vert) is getting the adjustments right.
Old Feb 26, 2013 | 12:26 AM
full house's Avatar
full house
I did the research but can't find the name of Corvette forum anywhere??? I saw different sites.
Old Feb 26, 2013 | 11:35 AM
Robert1Stock
What he said, replace the whole thing and you should be good to go!
Old Feb 26, 2013 | 12:14 PM
JetMechZ16's Avatar
JetMechZ16
My passenger window didn't work at all when I got my 04 Z06, I pulled the door panel off and took the outer motor housing off, I believe it's 3 or 4 allen bolts. You can get to all the bolts with it all still in the door. Then I cleaned it up, rotated it 180 degrees, as it will install either way, and presto the window worked again. Didn't cost a cent, just about an hour of time. You can always try it first before you spend any money.
Old Feb 26, 2013 | 01:29 PM
BryanV's Avatar
BryanV
Just got one $48.50 shipped
Old Apr 1, 2013 | 08:57 PM
BryanV's Avatar
BryanV
So back from the dead. A month later and still didnt change out anything BUT
Went for a tune the other day. The tuner hooked up everything reset the ecu got in and we went for a ride to street tune. I told him id roll the window to get some more air in but it dont work. As I said that I hit the button and it rolled down WTF first time in 2 months maybe more.
So it worked from the 29 up until yesterday and now its not working again. Im thinking electrical issues. Where should I look or is it the regulator.
Old Apr 2, 2013 | 08:08 AM
allred's Avatar
allred
I'm thinking it's coming down to the regulator.........
Check out the how-to video in this link.
http://forums.corvetteforum.com/c5-g...blem-ouch.html
Old Apr 2, 2013 | 10:48 AM
lxconv331's Avatar
lxconv331
Welcome to the wonderful world of GM products!! Typical issues for the C5 but an easy fix,,
Old Apr 2, 2013 | 12:12 PM
dadaroo's Avatar
dadaroo
Below is a link to someone else having a recent passenger window issue. It can provide some helpful info including how to remove the door panel.
Also, when I do Forum searches, I do it using Google and you get the Forum and others similar sites for additional assistance. I and others find this better than trying to directly search this Forum.
To Passenger Window Doesnt always work
