Shift Light help Tach signal?
Just got a Raptor shift light and having some issues installing same.
00 coupe, I found the wires under the dash, with the three White wires, and I tapped into each of them to test for the tach wire with no luck. If I have to get the signal from the PCM. How do you access same to tap into the correct wire?
Any help.
Thank you
Nick
Any help.
Thank you
Nick
