New Shifter Boot
Old Mar 1, 2013 | 10:20 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Default New Shifter Boot
When removing the old shifter boot on my C5Z, I read that it is stapled and lightly glued. Once staples are removed and old boot is carefully removed. How is the new one secured? By just re-gluing back with super glue or ? Thanks
Old Mar 1, 2013 | 10:35 PM
DooDooBear1999's Avatar
DooDooBear1999
Finally getting around to the MGW install? Are you reusing the plastic ring or one of the metal replacements?
Old Mar 1, 2013 | 10:47 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
I'm reusing the plastic ring, and yep I'm starting the install tomorrow morning
Old Mar 1, 2013 | 10:53 PM
DooDooBear1999
I'd assume you could just staple the new boot onto the plastic like the old one was. But not just regular paper staples. Something more along the lines of the heavier duty ones that are used in those staplers with the long handles on them. Gorilla Glue is also an option. When I switched to the metal ring, I spread a small amount on the inside of the boot in between each metal tab to bond the leather together when I folded it over the metal. I don't see why it wouldn't work with the plastic. You're going to love the shifter by the way.
Old Mar 1, 2013 | 11:06 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Thanks bud
That's takes care of the last of my doubts.
Old Mar 1, 2013 | 11:09 PM
Look at these instructions - they may help you out, especially steps 10-12.
http://www.vetteessentials.com/instr...t_install.html
Old Mar 2, 2013 | 05:56 AM
tentuna's Avatar
tentuna
Did my boot with a redline leather boot using the plastic ring over, just use a good interior adhesive and let it sit and it will stay forever, I think the only reason they used staples was to get around a cure time.
To New Shifter Boot
