From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Originally Posted by frenchsquared
why does the build spec sheet say some of these had an lt4? These are all LS1's.
Says the engine serial number will show if it is an lt4 or and lt1.
I'm not sure what you're seeing there. It certainly doesn't have an LT1/4 in it. Well, it better not anyway! I own one (Lt1) and thanks but no thanks, it'll be the last one for me!
I'd personally get rid of those Foose wheels pretty darn quick. They're likely pretty dang heavy. You can pick up a set of real C5Z wheels for a couple hundred dollars, and I'm sure it would make your car feel a bit better. Heck, if you don't like the Z wheels, you might be able to find a set of '00+ thin spokes STILL with tire pressure sensors.
But if you like the Foose wheels, more power to ya!
