Rear wheel backspace fitment question
Old Mar 13, 2013 | 01:30 PM
Sinister-one's Avatar
Sinister-one
Default Rear wheel backspace fitment question
Would these wheels fit on my FRC ?
19x12 C6 Zo6 wheels, 5x120 bolt pattern, +59 is the offset.
Old Mar 13, 2013 | 02:26 PM
Sinister-one
Thanks but it doesn't really help......
Anyone else ?????
Old Mar 13, 2013 | 03:15 PM
alextz's Avatar
alextz
That would equate to an 8.82 inch backspace for a +59mm offset 12 inch wide wheel.
The wheel will fit, but depending on tire and how aggressive you take corners, and how low you are it could rub a little. If you are going to run a 335 wide tire then it will rub a lot, a 315 tire, not so much, maybe a little, maybe not at all.
1/4 inch spacer would do the trick for sure, although I dont think you can put more than 1/8" spacer on the rear without installing longer studs.
In summary:
yes they will fit, but may rub a litte depending on tire. 1/4 inch spacer or 5/16s should make it all good, but you will need longer wheel studs, which you have to remove the hub to replace (at least on the rear).
One thing I probably forgot, is what is the overall circumference of the tire you plan to use, if it is larger than stock, you may have rub issues as well (can be solved by running higher ride height in back).
hope that helps.
Old Mar 13, 2013 | 07:12 PM
Sinister-one
Sorry... after looking back at "calculator" I saw that the wheel would stick out past the rear fender about 3/4". That's the answer I really didn't want to see... Oh well, so much for buying those wheels.
Thanks for all the help guys !
Old Mar 13, 2013 | 09:24 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i run those wheels.
they will stick out too far beyond the stock quarter panels or will stick too far inward on a 2" flared panel.
but yes, they will bolt on and fit your FRC.
Old Mar 13, 2013 | 10:35 PM
Sinister-one
Originally Posted by jdmvette
i run those wheels.
there's one in every crowd.......
To Rear wheel backspace fitment question
