Climate Control Display FIXED!
Old Mar 13, 2013 | 10:22 PM
DeeHutch's Avatar
DeeHutch
Default Climate Control Display FIXED!
I had contemplated leaving this up to someone else, however I decided it could be something to start off my bonding process with the car.....
So, I tackled it....with this guys help.
http://www.brookins.us/accontroller/dimacdisplay.html
As you can see in my before pic, mine was completely gone. The hardest part I thought was getting the console to go back together correctly!
Old Mar 13, 2013 | 11:06 PM
LS2NSUV's Avatar
LS2NSUV
Don't ya just love the feelin' of self accomplishment.
Nice work.
Old Mar 13, 2013 | 11:14 PM
Nice job on the repair. It's great when you can do things yourself instead of paying a lot of cash to someone else.
Old Mar 13, 2013 | 11:17 PM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
Great job. Every little mod/fix you do makes you more and more familiar with the beast.
Old Mar 13, 2013 | 11:18 PM
VETJAZZ's Avatar
VETJAZZ
Congrats!!
Old Mar 13, 2013 | 11:35 PM
lion149's Avatar
lion149
nice job!
Old Mar 13, 2013 | 11:42 PM
DeeHutch's Avatar
DeeHutch
Thanks guys, and yes, I do love the sense of accomplishment!
Couldn't have done it without the forum though!
Old Mar 13, 2013 | 11:45 PM
Jrockk's Avatar
Jrockk
Congratulations always feels great when you see it and realize you fixed it for free
Old Mar 14, 2013 | 12:07 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Great job!! On my list......
Regular soldering iron or "cold" solder?
Old Mar 14, 2013 | 02:25 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Grats!!
Regular
Old Mar 14, 2013 | 08:31 AM
DeeHutch's Avatar
DeeHutch
Originally Posted by Chilliwack vettes
Grats!!
Regular
Not only regular, but a cheapie $5 one from Wally World, with no temp control!
Old Mar 14, 2013 | 08:36 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Good job ! Nice to fix it yourself huh ?
I wrote a similar procedure on my web site !
www.ToqueZ06.com
Toque
Old May 19, 2013 | 10:36 PM
C5Conrad's Avatar
C5Conrad
I had my display 'fixed' by someone that doesn't necessarily fix these things. When the parking lights are off, the display is dimmer. When the parking lights are on, it gets brighter.
Shouldn't it be the opposite way around? What needs to be changed?
Old May 28, 2013 | 04:39 PM
Coach32's Avatar
Coach32
OK....I've been reading the threads on this topic since I bought the car. 2 hours ago I read a response that got me off my azz went out to the garage and tore into it. I have a convertible so factor in the "water fall". Followed the directions without a hitch.
The resistors on the circuit board appeared to be perfect, but as someone else said, re-soldered anyway. 2 moved as soon as I touched them. The others I did pretty well. Got those 2 soldered in place but very sloppy. I connected the unit in the car to see if I had accomplished anything....walla.....full bright display. I was going to go back and clean-up, but said screw-it. It's working perfect, put it all back together an be happy. I can see the display day time and the night time dimmer works as well. Cheers to the guy that figured it out...bless you my son.
Old May 28, 2013 | 08:50 PM
DeeHutch's Avatar
DeeHutch
One would think that's the way it should work, however, I have no ideal what your guy did wrong, or how to attempt to fix it.....
Good luck!
DeeHutch's Avatar
DeeHutch
Good for you man!
Old May 28, 2013 | 09:59 PM
corvette77's Avatar
corvette77
I fixed mine this weekend using Toque's proceedure.
I don't think I have seen the display so bright, now it makes the radio look dim.
The only hard part was keeping the fuel tank connector plugged in, that wire needs another couple of inches on it.
Old May 28, 2013 | 11:43 PM
jrose7004's Avatar
jrose7004
I need to do that, mine is dim but not completely gone.
Old May 29, 2013 | 12:01 AM
duramaxsky's Avatar
duramaxsky
When I did mine one resistor came loose and was a pain to get back in place. I discovered if you pry up gently on each end you will find where they are not connected. I soldered that end first and no more got away. It is a great free fix though.
To Climate Control Display FIXED!
