battery
Old Mar 14, 2013 | 09:14 AM
black match box's Avatar
black match box
Default battery
Is there any way to disconect your batt. and not haveing to re-program any of the computer fuctions on the DIC.? I thought I saw here once that someone hooked up wires to a 9 volt batt. and attached them to the neg. and pos. cables before undoing the batt. and that the car keeps its memory. does anyone know if this is true, or has anyone done this. thanks
Old Mar 14, 2013 | 10:26 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I've used a set-up I got from a auto part store which uses a 9 volt battery with a plug u plug into a power outlet like the old cig plug. Plug in the 9 volt b-4 unhooking your battery.
Old Mar 14, 2013 | 10:42 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
That will work, But it only takes a couple of minutes to re-program everything.
Old Mar 14, 2013 | 11:01 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
I've disconnected my battery many times and also had a few dead batteries along the way and never had to reset the DIC. It does reset the page which I need to reselect, but other than that, no functions or information changes are required. The only other item is the radio. If you have set the security settings, then you will need to input your code but all the stations are still live.
rr
Old Mar 14, 2013 | 04:10 PM
Same here. Not a big deal to reset whatever needs to be done to get it back to the settings before the battery disconnect.
Old Mar 14, 2013 | 04:16 PM
maxx2200's Avatar
maxx2200
+2. I've never had any issues after battery was disconnected.
Old Mar 14, 2013 | 06:40 PM
jerrys vette's Avatar
jerrys vette
i disconnected my batt 4 mths ago. where do i get the code for the
radio if thats all i need , when i get new batt this week?
To battery
