[Z06] Clutch response?
Old Mar 18, 2013 | 09:34 PM
Titan22's Avatar
Titan22
Default Clutch response?
I've had issues with high rpm shifts and the clutch either not wanting to come up or just loosing it's "spring". I've sucked out and replaced the fluid in the reserve over and over again trying to get as much of the fluid with what I understand the be clutch disc dust in it out. Anyone have any recommendations on what to do to fix it?
Thx
03 Z06 25,000 miles
Old Mar 18, 2013 | 09:49 PM
bumble-z's Avatar
bumble-z
I have an 03 Z06.
My car developed the same symptoms as you described.
I've always kept the fluid clean.
Every day driving, there is never a problem.
Go to the strip and it started exhibiting the same symptoms as you mentioned.
Being it still has the original clutch, p/plate t/out bearing, slave & clutch master cylinder.
I had heard that installing a Tick adjustable M/cylinder may/might
take care of the problem.
Well, I figured I start there before doing a tear down of the other parts.
Low & behold & two years later, no more problems .
Old Mar 19, 2013 | 01:35 PM
skyavonee's Avatar
skyavonee
Especially if you have aftermarket headers, these two things may offer a noticeable increase in clutch performance (although probably won't cure your problem completely):
- use a high performance fluid in the clutch, like ATE Super Blue, Motul 600, or Castrol SRF
- wrap the clutch line in a thermal barrier where it's nearest to the headers. Two or three layers of this - http://www.firesleeveandtape.com/AB-...g-S-FS-VCL.pdf - followed by an outer layer of this - http://www.firesleeveandtape.com/AB-...-FG-AL-VCL.pdf - will work well.
Old Mar 19, 2013 | 04:14 PM
zeevette's Avatar
zeevette
I'm with Bumble..... just install a Tick MC, and see improvement. Everything else that fixes the problem is much more expensive, and alot more DIY work.
Old Mar 19, 2013 | 07:59 PM
Titan22's Avatar
Titan22
Thanks, looks like I'll go with the Tick MC!
Old Mar 19, 2013 | 08:09 PM
bumble-z's Avatar
bumble-z
Are you going to do it yourself or hire it out?
Old Mar 19, 2013 | 10:16 PM
Titan22's Avatar
Titan22
I'll do it myself.. That's the fun isn't it..
Old Mar 20, 2013 | 01:21 AM
Z06ster's Avatar
Z06ster
....I had heard that installing a Tick adjustable M/cylinder may/might take care of the problem........
Here's what I can offer about the Tick Master Cylinder... because I had one:
The first 1/3 of the pedal excursion weighs a ton. The second 2/3 of the pedal excursion feels close to stock. Because of this, the feel of the entire pedal excursion is not uniform. The clutch grips virtually instantaneously in the first 1/3 "heavy zone". In my opinion, this unit is not streetable but great for the track.
In case anyone is wondering, I did contact Tick Performance to see if I could address these issues and they told me this was the way it was. I removed this thing from my car after 5 days and 120 miles.
Old Mar 20, 2013 | 03:36 AM
Wood81's Avatar
Wood81
Its perfectly fine on the street once you get used to it it is second nature. Much better over the stock GM one.
Old Mar 20, 2013 | 10:18 PM
Z06ster's Avatar
Z06ster
Really??... you do at least agree with my description of the pedal excursion and how fast the clutch grabs, right?
To the OP and others....You can buy a stock 2004 Z06 clutch master cylinder that fits on all C5's. It is an improvement over the original one.
Old Mar 21, 2013 | 06:07 AM
Wood81's Avatar
Wood81
Yeah, I agree that it grabs a lot faster. Since I put headers/ full bolt ons on my Z06 the clutch pedal has been sticking to the floor, I need to get a Tick M/C bad. I had one in my last car (H/C/I/E car) and it solved the problem.
Old Mar 21, 2013 | 06:08 AM
Wood81's Avatar
Wood81
Where did you get your bumper? Not trying to jack thread, you can PM me if you want.
Old Mar 21, 2013 | 01:08 PM
zeevette's Avatar
zeevette
Yeah, mine's super grabby, too. I thought it was the nature of the new clutch. I'm getting more used to it, but still wants to stall in traffic sometimes.
Old Mar 21, 2013 | 01:17 PM
MX621's Avatar
MX621
The tick deff has its down falls... does help high rpm shifts, but it makes even the stock ls6 clutch very difficult to slip/modulate and has uneven pedal feel vs. Pedal travel. I wanna try putting the clutch assist spring back in.. see how that effects the feel. But i am considering removing the tick..
Old Mar 21, 2013 | 01:23 PM
Wood81's Avatar
Wood81
Interesting that you guys didn't like it. I just bought another one for my Z06 hopefully it solves my problem of the sticking to the floor. I'm installing a speed bleeder too because it seems the fluid gets dirty super easy
Old Mar 21, 2013 | 01:28 PM
bumble-z's Avatar
bumble-z
I still have all the original LS/6 clutch components.
Every thing other than the Tick installed.
I noticed a little (not much) increased pedal pressure. (no problem)
Other then that, every thing else is pretty much the same...
other then no more spongy pedal & pedal not wanting to come back up
after high RPM shifting.
I absolutely love the Tick adjustable clutch M/C.
Old Mar 21, 2013 | 07:56 PM
Bobtam's Avatar
Bobtam
My 03Z had the pedal to the floor problem. Did the Ranger flushing and still stuck to the floor. replaced the master cylinder 2004 upgrade and still stuck to the floor. Installed a remote bleeder and bled the crap out of it. Still stuck to the floor.
Replaced the clutch with a Monster stage two with lighweight flywheel new slave and insulated the lines.
No more sticking to the floor. Stock clutch was in good condition but was probably slipping at high rpm and overheating the slave. Problem fixed for good I hope.
Old Mar 21, 2013 | 09:34 PM
youngrigo's Avatar
youngrigo
Im making over 550rwhp and use a stock master with no problems shifting at high rpms or peddle sticking... Not a fan of the Tick master personally
To Clutch response?
