I'm redoing my engine bay AGAIN and one of the things I want to do is dress up the hose clamps. Does anyone use these and know what sizes I need? Thanks! BTW... this is something similar to what I am looking for.
I just don't know what sizes I need for all the hoses. I got some nice braided covers for all of the hoses, I found some expandable stuff and wanted to finish the ends with these clamps.
Me too, I'm doing a replacement radiator hose replacement project. What size radiator hoses do C5s come in.. ID / OD. Planning on getting the stainless steel braided line kit but want the above clamp covers as seen above. Eckler's had a pre-braided upper and lower at one time, now only WCC has them at $100 each upper / lower.
Hmm... upper and lower radiator hoses, the heater core hoses on the side of the pump, the hoses that go to and from the coolant reservoir, the hose that goes from the upper passenger side of the radiator to the front coolant crossover. I have an LS2 TB so my TB coolant is bypassed.
Upper Rad is 1-1/4
Lower Rad is 1-1/4 and 1-1/2
Heater hoses are 5/8
Overflow to Rad is 3/8
Overflow to block is 9/16
Valve cover to TB is 3/8
The hose you deleted is 3/8
Drivers side Air hose is 3/4
Upper Rad is 1-1/4
Peace
Chip
Thanks! Do you offer a kit? If not, you should. I bet there's enough demand that you could sell quite a few.
We use to.
Problem is everyone wants a different type of clamp.
At one time we had 14 different clamps in 4 colors and 5 sizes.
We could not make any money vs the cost of stocking all the
different types so we dropped them all together. Margin is <10% so any
inventory that had less than 20 turns per year was a negative revenue drain
Peace
Chip
I already have something similar for my fuel lines and electrical. I'm completely redoing my electrical in the next week or two, as well as a bunch of other stuff. Here's what it looks like now:
I'm redoing my ignition too, and putting the battery back in the trunk. I have the LPE battery relocation kit already installed, but I moved the battery back up front when I was trying to troubleshoot a stereo noise gremlin.
