[Z06] Help with bolt ons!!
I am looking at 2inch or 1 7/8 looks headers with the kooks catless x pipe to 2.5 borla no muffs.. Vararam intake.. Maybe underdrive pulley, throttle body, porting, and radials?
Any numbers or advice or sizes and opinions will help!
Ps lost my 468rwp goat:/ bought an 04 z
They are also the most expensive. I wonder why?
It is hard to tell by a post, but slow down and do your research. "Buying this week" without fully informing yourself can cause problems. Just my two cents.
As far as your mechanic telling you the 2" headers are not for your set up, he is right. It is like putting Heads on your car for a 4.0 or larger bore. It will not optimize your set up. Horsepower and TQ is dependent on how well air/fuel/spark burn occures within the cylinder.
When everything port matches (Intake>MAF>TB>Intake> Heads> Cylinder Bore> Headers>Exhaust) and an incredible tune you have great atomization of fuel, swirl into the cylinder then spark ignites at the perfect moment. All of this happens because you have flow without flow then it is tough for a tuner to do his job...Just my take on it.
I would do the underdrive pulley when you do the cam to save some labor. It's not as easy to do as it was in your GTO, you have to pull the steering rack out of the way to get to the balancer which adds extra labor. If you do it during a cam you kill two birds with one stone.
I'd personally skip the throttle body. My first mods would be, intake, headers, catback, thermostat, and a dyno tune. Then I'd look into doing a cam for more power, or, going the supercharged route.
I would do the timing chain during the cam install for sure. As for the water pump, you can do an electric one which usually frees up 5hp or so, but they are a bit costly.
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Mail Order Tuning & Sales
704-307-4227
A good cam like a COMP 228-236 .600/.600 change the Valve springs. 425/400 RWHP/RWTQ....
If you plan on doing the heads then do the intake/TB: 440/410... Other than that the LS6 intake is all you need,it really is a good intake. I recently read a article about a cammed LS3 in GMHTP they had a H/C/E set up and when they switched to the LSX102r they gained nearly nothing. 5hp is not worth 1200.00 bucks to me.
http://www.gearchatter.com/viewtopic10974.php
I am in no way trying to persuade you not to get the FAST, by all means if that is what you want then do it. I just think you could save your cash for a better upgrade like a cam or heads and cam.
