Headlight gear issue
Old Apr 7, 2013 | 03:14 PM
nascar57's Avatar
nascar57
Default Headlight gear issue
I wanted to replace a bad hid bulb so I opened the right headlight manually, remove the entire bucket so I could check all the connections and tighten the tabs than hold the hid bulb in place. Re-assembled everything and now the right headlight grinds for a few seconds before shutting off. They open and close normally other than the grinding issue. It worked perfectly before I took it apart and have done this before with no problems. I cant see why the gears would have gone bad just by removing and re-installing the bucket. Any ideas?
Old Apr 7, 2013 | 03:46 PM
Chicago1's Avatar
Chicago1
maybe it was just a coincidence and it's time has come to put in a brass one.
Old Apr 7, 2013 | 03:57 PM
nascar57's Avatar
nascar57
not sure what else to do, have tried tricking them into the right position without the grinding but no dice. Maybe its using a different position on the gear now that I manually changed it.
Old Apr 7, 2013 | 04:16 PM
Chicago1's Avatar
Chicago1
No they are just stripped nothing you can do but change to a brass one. it's not that hard and cheap like 50 bucks.
Old Apr 7, 2013 | 06:04 PM
grunz95's Avatar
grunz95
Default headlight gear
I was finishing installing the HID's and my passenger side starting to make the same noise as the drives side did last year. I'm glad I brought a set of gears. Changed it out and no problem. Now I have to wait until tonight to adjust the headlights.
Gary
To Headlight gear issue
