driver's seat bladders
Old Apr 8, 2013 | 04:04 PM
buddyfew's Avatar
buddyfew
Default driver's seat bladders
replaced all 4 bladders in seat,but side bolsters not working even tho the compressor does , could be tubing connection at compressor. any advice? much trouble to take out the seat? thanks.........
Old Apr 8, 2013 | 06:55 PM
dmarkshark's Avatar
dmarkshark
More than likley broken at the bolster. Did you check them when you put the other ones in? Its is also possible for the compressor to be working, but not blowing air as the vacumn part can go bad. You can check under the seat and see if it is indeed blowing air, I had to replace mine and it seemed to be working but not. I tried to take it apart to see how to fix it, but it was not apparent to me.
