Emergency Flasher
Old Apr 9, 2013 | 05:32 PM
G Atkins's Avatar
G Atkins
5th Gear
Default Emergency Flasher
I find this forum very helpful I couldn't afford this C5 if you weren't here to help so thanks. I just changed my turn signal flasher and thought everything went fine until I connected the battery. Now the emergency flasher want turn off. When pushed in the lights work fine when released the indicator light goes off however they continue to flash. When the key is off they are off as soon as the key is turned off they flash. When the flasher is released the indicator light is of and when pushed in it is on. Sorry for so many words to explain I can't figure out. Thanks Gene
Old Apr 9, 2013 | 07:24 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Was it a new flasher you installed?
