Headlight swap
Any help is greatly appreciate it.
I had a set on my car and really didn't like the looks and rook them right off.
Just yanking your chain a bit.
DEPO: These lights have by far the largest “frog eyes” of any of the fixed headlights and are almost as bad of a aerodynamic drag issues as pop ups….except they don’t retract. The Depo lights are also prone to micro-fracturing due to the poor quality plastic used in the main lens.
Specter Werkes: Slightly more aerodynamic than the Depos, they still have the frog eyes. The mounting platform produces a notable vibration in the headlights. The lens mounting design uses exposed screws that some may find aesthetically questionable
Type 66: A little known fixed kit that uses poor quality optics, and materials….not to mention a frog eye lens.
Breathless: While the lens and mounting system are a good design, the parabolic reflector low beam has relatively low output and poor pattern…even with the Catz voltage booster.
Radioflyer SLC V2 headlights:
Aerodynamics nearly equivalent to the factory setup with headlights lowered. The ONLY kit with Bi-xenon projector main beams and HID kit included. Independently adjustable inner and outer projectors. Many upgrade options available.
The SLC V2 Kit includes:
- (4) Morimoto Mini custom designed Bi-xenon projectors. (inner projector modified for high beam with no cutoff)
- Reinforced Aluminum mounting Frames
- Stainless Hardware
- Lightweight and durable (and paint-able) ABS Shrouds
- Impact and UV resistant PETG Main lens
- 55w slim HID kit with Ballasts and Bulbs
- 55w Halogen High beam bulb,
- Hi-4 relay circuit
- Detailed installation instructions via Download link.
Is it worth the cost? Only If you want the best.
You can purchase them here:
http://www.shop.radioflyerinnovation...lights-007.htm
ARRR
Glad you're out of that phase...
