We don’t just sell you a set of brake pads; we deliver unmatched customer support and technical help. Carbotech Performance Brakes are also leading the way with Pro, Grassroots and Track-Day/HPDE groups and drivers. We can help you find the perfect set up for your vehicle by having an entire line up of street and track compounds for your application. Contact info is below if you need some help or would like to order a set. Orders place direct through me receive 5% forum discount.
From street use to the higher performance demands of track days, we'll help you achieve better brake modulation, torque and fade resistance. High-tech construction means better stopping power and a higher level of driver confidence every time you get behind the wheel.
Carbotech brakes utilize a ceramic and metallic construction in a range of compounds that out-perform competitive brakes. Carbotech brakes are made from compounds that offer higher initial bite, torque and fade resistance—providing consistent brake modulation and performance over a wide range of operating temperatures.
Do you sell a street pad that can be used for 2-3 HPDE and a few AutoX per year?
We make a pad that can be used on the street and do HPDE and AUTO X. It is the XP8 you will have some noise and dust. The dust is 100% non corrosive it will not harm your wheels or paint.
A high torque brake compound with a wide operating temperature range of 200°F-1350°F+ (93°C to 732°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Excellent as a front brake pad for lighter applications weighing around 2,400lbs or less. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
I will help you determine the perfect brake pad compound for your car and your style of driving. Carbotech brakes are designed to allow you to “Go Deep!” while being particularly rotor friendly and contain 100% non-corrosive brake dust.
