2000 c5 radio issue...
Old Apr 15, 2013 | 12:25 PM
Mike Ramsey's Avatar
Mike Ramsey
Default 2000 c5 radio issue...
Anyone have trouble with their factory bose headunit not keeping the radio stations that you preset in it?? Seems like if i drive mine and stop and park it overnight the stations are all 88.9 or something?? Any help would be good....Thanks in advance,
Mike
Old Apr 15, 2013 | 12:45 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Mike
Keep in mind that unit is 13 years old and things happen, I would make sure the memory fuse is good for starters, If all checks good I would look for a replacement. You can always contact Dennis at DoubleDMods.com a forum vendor that can answer your questions or sell you an upgrade for a really decent price.
Mr.Bill
Old Apr 15, 2013 | 02:47 PM
Damillio's Avatar
Damillio
Originally Posted by 8VETTE7
Try setting the DIC display to something like engine temp. Then let the car sit overnight as you are doing and when you start the car I'll bet the DIC display is at mileage which is the default and not engine temp.
If that happens, expect to be replacing the battery soon!
Try this
Old Apr 15, 2013 | 08:38 PM
Never had a problem with the radio keeping the presets. But...
I'm betting this is more likely a battery issue. Loose or corroded battery cables including the one at the starter or a battery that is about to go away. When the car is started on a weak or bad battery car, the voltage can drop below a critical level that retains memory on things like radio presets and non default displays in the DIC, HUD etc.
it does sound like maybe the battery could be going bad.
Old Apr 15, 2013 | 08:50 PM
65GGvert's Avatar
65GGvert
Just to eliminate a possibility, next time you're in the car press the #1 memory button then press the #2 memory button and see if the radio presets are at 88.9 or whatever you saw on either of the two memory buttons.
To 2000 c5 radio issue...
